Not yet. What specifically would you look for? Ill go through them all but is there something that is finicky with these things i should know? I ordered the Pertronix ignition and coil and that should be here tomorrow as well.
#12
UPDATE: Today I got the Pertronix ignition and installed it, and re set the timing. I charged up the battery, and messed with the fuel/air screw. She runs and starts like a CHAMP!!! The fuel screws were only turned out 1 turn, so it was starving for fuel. Turned it out another turn on both sides and bang, idles smooth, starts super easy, and purrs like a kitten! Thanks for all your guys help! much appreciated!
#13
ttyl |
#14
#15
So we had a decent time out in the water this weekend. Boat seemed to get hard to start again. Would always have to pump the throttle back twice for it to fire up even if the motor was shut down just to pick up someone out of the water. We did notice the boat got kinda warm and saw smoke coming from the engine compartment. We inspected the water pump impeller and it had burned up. We replaced it, and also noticed the top water line to the pump had a huge leak, which would have cause the boat to continuously loose prime if my thinking is correct. Got that fixed and it ran great. Now im thinking we need to overhaul the carb. How do I identify what carb i have. I know it is a Holley, but not sure of a model???? how would I find this?
#16
#17
Post a picture
#18
The numbers you need are stamped here.
