I would confirm the timing is set properly Double check wiring connections with the instructions. Which EI are you using? Confirm firing order is correct. Confirm all plug wire and coil wire connections are good. Confirm choke is open.
#12
I just went thru the timing game on mine yesterday. It does vary a cOuple of degrees on the angle viewed. Holy parallax batman
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
#13
Agreed.
PCM 351w, 350hp |
#14
[quote=TRBenj;849019]I can tell you- not good! I learned that the first time I set the timing on my '71 Correct Craft... which has a standard rotation balancer on a reverse rotation engine. Runs like crap with initial set to 10 deg ATDC. QUOTE]
There are two ways to learn........ ![]() ![]()
#15
You can easily tell moving it retarded anywhere near 0 or ATDC, it degrades instantly.
Firing after the piston is on the way down - just killed the whole process. It can be done by ear just as well under load, by backing off the moment ping starts in advancing it. Now see where the light hits after. Now it's tuned to the fuel used. Timing is 6 BTDC. Granted if carb is 100%. |
#16
Yup
Still falls on its a**
Ok, re-timed it this morning... 6 Degrees looking top down. Sounded great in the driveway but as soon as I get it in the water at full song it falls off at 30 MPH. Next up is the plugs, wires, and cap... (which I dont think will make a diff but worth a shot before going back to points.) What is the gap again? (with Electronic? 32?) Cj |
#18
Did u replace the coil when u put the petronix in? If u did, put your original coil back in. I was sold a faulty coil and couldn't get the boat to run right. Finally narrowed it down to the new coil.
#19
Coil?
cj |
#20
A bad coil could do that. They usually either work or don't, but it is possible.
