Old 06-17-2012, 05:04 PM
AZX9's Avatar
AZX9 AZX9 is offline
Boat: 2003 Mastercraft X9, MXC 350
Ballast won't overflow
So I was filling the ballast yesterday On the x9 and now for some reason the bags will get tight as a drum and not overflow when full. Isn't this just a free flowing outlet that doesn't have a valve to open?
Old 06-17-2012, 05:06 PM
sand2snow22's Avatar
Boat: MC
Should. Make sure the overfill line isn't pinched or blocked. You sure its full, full?
www.nwboatsports.com
Old 06-18-2012, 12:33 AM
AZX9's Avatar
Like bulging tight as a drum tight.
Old 06-18-2012, 10:08 AM
bhyche bhyche is offline
Boat: 1984 SnS 351
check for dirt dobbers in overflow line.
Old 06-18-2012, 09:52 PM
AZX9's Avatar
Where do the vent line run? Do they come back to that block where all hoses come together? Where ever its plugged it's affecting both the ski locker ballast and the rear ballast so they must be connected somehow.
Old 06-18-2012, 10:33 PM
Boat: MC
Follow the lines from the sac. They should vent out of the boat above the waterline.
Old 06-18-2012, 10:46 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: 2000 X-star
Your vents may have a check valve in them which is a flapper type. I an not 100% sure on the x 9 system but they may share the same outlet. If in fact they do share the same outlet then 100% for sure there is a check valve on each line.
Over the winter the flap may become stuck or over a period of non use. Most of the time the pressure from the bags will bust through. I would check the lines and maybe the bags when they get full are pinching the vent outlet.
2000 X-Star, 3000lbs ballast, LTR 330, Acme 1235 14.5X14.25prop.
