Hogwild,
I like both the JL Audio and Wetsounds coaxials. Both have the best midbass by far. The JL Audio has a coated silk soft dome tweeter that is very detailed while very smooth. And, a linear response is essential for a good image. Personally, I am a fan of the Euro style tweeters from Vifa, Seas, Audax, etc. and JL Audio absolutely subscribes to this sound. Many like the Wetsounds titanium hard dome tweeter because it is a bit more aggressive and that little extra emphasis makes everything sound a little more distinctive. And, I like the Wetsounds XS-650 too because it is not over-bearing in this respect. But, there are many others coaxials that are soooo bright that they ruin the musical balance and make vocals strident. In fact, I have to wonder if the designers of many coaxials have suffered severe hearing damage because they make their speakers so bright. Or, maybe they just want to stand out as the brightest speakers in the soundboard. While it may get your attention out of gate this type of speaker quickly fatiques me. That is what I hear. I listen with a more analytical ear than most. Sound is subjective according to the health of your hearing, what you are accustom to and your past influences. Not everyone is going to agree with what sounds best. David Earmark Marine
www.earmarkmarine.com |
#13
Also, why to the companies mean when they say the speakers are a component style coaxial speaker?
#14
Component separates the tweeter from the midbass driver whereas a coaxial will have the tweeter in the middle of the midbass driver (generally).
Component - Separate tweeter and midbass drivers: Coaxial - "all-in-one" so to speak: ![]() |
#15
I'm replacing the speakers in my 02 xstar and I'm leaning toward the Polk DB's. Is there an appreciable performance difference between the 651 coaxials in the $60 range and the 6501 components in the $120 range. I am generally content with factory car audio so the expense of high performance is normally a waste on me.
Can I get some thoughts on my needs? I'll be replacing the tower speakers also. I'll probably go with the same speakers in the cabin and the tower. unless there is a compelling reason to go with something else in the same price range. Wetsounds and the like would be under utilized in my boat. |
#16
The 6501's are about twice the power handling capacity and will be a better speaker setup. You're probably in the same boat as me and have eight 6.5 separates and don't want a hole left or want to leave the old clarion tweeter in. The 6501 would sound better at the same sound level as the 650 also. Another key to consider is your amp output.
#17
I have the original clarion 4 channel amp in the boat and I also have a Clarion XN3410 4 channel and a Clarion XN3210 that I purchased when I thought the original was shot.
With these amps available for use and the intention to replace the speakers with either 651's or 6501's how should I set this system up? and do the amps available change the speaker recommendation? |
#18
AZX9, If you do not want to go with components or leave the old Clarion tweeters as dummies, swap them out with LED courtesy light assemblies. |
#19
Sorry its been a while since I was here.
I ordered 6 Polk 651 coaxials to replace my existing speakers (4 cabin and 2 tower). I have the existing amp (Calrion APX480M) which powers all six speakers and the original sub. As previously mentioned, I have an XN3410 and an XN3210. So, should I go with the XN3410 for the cabin and tower (as MLA mentioned) and the xn 3210 for the sub? Does this configuration provide proper balance? We do not like the volume in the Cabin real loud but it would be nice to hear the stereo at the end of the rope. Is there a way to achieve this mix?... and of course without sinking a lot of money. Last edited by ddummitt; 10-05-2012 at 01:59 PM. |
#20
1 Corinthians Chapter 13 - 11 |
| Tags |
| audio, speakers, tower |
