#51
well...the strut is tweaked ever so slightly...just bent a hair..what options are there to get it straight..its off about 1/2 an inch or so.
#52
Buy a new one. That is not an item that you want weak, cracked, or damaged in any way. That strut is under extreme force running that boat and if it were weakened in any way and eventually broke while running the boat............Well that would be bad.....Real bad
Heating it and bending it back straight could possibly make it weak.
Rollin' Gangsta Style Quote:
#53
I came in on this thread too late. I had the same issue on my 95 V-drive and I kept messing with it for a few weeks. I quit guessing and ordered a new strut/bushings. I had my shaft checked at a local machine shop and it was fine. I put it all back together aligning the strut and shaft with the hole in the hull first, then aligned the motor to the coupling. The amount of effort required to turn the shaft will vary depending on your exact alignment and how long the bushings have been out of the water. My boat is out of the water during the week and some times the shaft "sticks" a little before I can turn it by hand. Once it breaks free I can turn it with two fingers but it is tight. The final alignment is supposed to be done in the water because the boat does flex some when it's put on the trailer.
“You realize your odds of winning the lottery are the same as being mauled by a polar bear and a regular bear in the same day”….E-Trade Baby. |
#54
I've heard stories of people using the propshaft as a lever, and bending the strut back into alignment. Others have removed the strut, oval'ed the holes, then reattached it using the propshaft to hold the strut aligned with the shaft log while the screws are tightened and the adhesive cures.
It's your boat, you can make the choice. Personally, bending the strut back to alignment gives me the willies. I'd probably buy a new strut if it were my boat. /frank
1998 Maristar 200VRS ![]() |
#55
i think im gonna just get a new one.
#56
other than skidim where should i shop..looking for a good price...any suggestions?
#57
http://item.mobileweb.ebay.com/viewi...assified=false
http://www.waterskis.com/200299-p/ma...ft_1_strut.htm
/spôrk/ a spoon-shaped eating utensil with short tines at the tip |
Thread Tools | |
Display Modes | |
