Update....
So I took the battery back to wal mart (yes wal mart) and had them do a test and it came back 'replace battery'.. I went ahead and went for the upgraded version--690 cold cranking amps was the most I could find in my battery size. Original battery was 625. The book says that for my engine I need a minimum of 750 cold cranking amps...?? I couldn't find that many in the battery size? Anyway it's installed--hopefully successful run when I take it out Saturday. I will post results. Thanks again for all the tips and advice! I'm a new and very excited boat owner! |
#12
What is the average time to crank it before it starts running? If it's much more than 5 seconds, it's taking too long and the battery will be run down for a while immediately after it starts. As posted, pumps draw a bunch of current and anything that acts as an electric heater is about as bad as it gets. You should also make sure the battery terminals/clamps are clean and tight- do the same where the ground cable bolts to the engine block. If these are dirty, you'll see exactly what you're describing. |
#13
I took the battery out and had it tested at wal mart. The result was 'replace battery'! So I got a new battery-even upgraded it to a better one--and installed it. Yesterday had the boat on the lake with no issues so far.. Fingers crossed but it looks like bad battery after all.
Thanks all! |
#14
