Old 04-28-2012, 08:14 PM
Chrisoswald Chrisoswald is offline
Boat: 88 Prostar 190 & 2006 Chaparral Sunesta 232
How easy should the prop turn by hand
Have a 88 prostar and was curious to see how easy the prop should be to spin by hand when the boat is dry.
Thanks.
Old 04-28-2012, 08:15 PM
on my 95 it spins freely... how's the cutlass bearing look?
Old 04-28-2012, 08:39 PM
It looks good as far as I can tell. The prop take both hands to turn. I would classify it as hard to turn by hand for sure.
Old 04-28-2012, 08:51 PM
Jerseydave's Avatar
TT Hero
There should be some drag when turning the prop so if you're use to an I/O or outboard it will spin way harder than those. There should be no up and down play in the bearing and the bearing material should look uniform all around the shaft.
If the boat has been on the trailer all winter and you're trying to turn the shaft it will feel extra tight until you run the boat in the water.
I was njskier on here.
Old 04-28-2012, 09:31 PM
Thanks for the info. I had read some posts about being able to turn the prop with one finger and that seemed almost impossible to me considering the strut and shaft packing. I ran it for a long time Friday and no vibration and the packing nut never got hot so I think I'm properly aligned. May unbolt the coupler to see if I'm aligned properly.
Old 04-29-2012, 12:40 AM
Boat: 1998 Maristar 200VRS
Posting the obligatory "How to correctly align your propshaft once in the boat's lifetime" doc.
Do it once, and you'll be able to rotate the prop with one or two fingers. I can do it with one, but it hurts. Two is a more reasonable measure on mine. It made a significant difference in smoothness when I did it.
Needing two hands suggests to me that you should do this.
/frank
Old 04-29-2012, 04:58 AM
CantRepeat's Avatar
Boat: No Boat
Once aligned correctly you should be able to spin the prop with one finger.
Tim
Old 04-29-2012, 09:17 AM
Thanks a million guys...im off to align...wish me luck!!!
Old 04-29-2012, 09:22 AM
93ProStar205's Avatar
93ProStar205 93ProStar205 is offline
Boat: 2004 x-10 mcx
My 87 poweslot was always rather stiff. Almost a two hand deal, but fine when in the water. Certainly an alignment check won't hurt.
wow..i just read that document..seems like a bear to do
