Does a higher pitch flexing compensate for the lower pitch flex?
Rollin' Gangsta Style Quote:
#22
Higher pitch will decrease the low end as well as drop RPM relative to speed, you may see a slight increase in top end, 1-2 MPH. I would not suggest a 19.5 with a 5.7 engine as it may not allow the engine to see max RPM.
Eric Johnson Johnson Propeller Co., Inc OJ PROPS 800-359-9730 |
#23
I guess I will save my money then. Just figured I would ask since nothing happens after 4700 rpm speed wise but the engine can turn another 400 rpm without change. I was thinking that a 19.5 would lower my rpm by 300 ish rpm but I would still get performance to 4800. The prop I'm running now is a monster out of the hole and I figured that a little less hole shot would not matter that much. Again Thanks for the advice.
#24
I have little experience with the newer XMP OJ's out of the few Ive tried for the 1.23's (lower prop RPM), but I know someone who saw the exact same behavior youre describing with a new XMP on a 1:1 boat. The last few hundred RPM didnt speed the boat up. In his opinion, the Acmes arent as susceptible to this phenomenon... they turn RPM's into speed a bit better. You may want to try a comparable sized Acme... my guess is that it will turn similar RPM's at skiing speeds, but will drop your revs slightly at WOT, if it bites and pushes the boat instead of flexing. I would not expect a steeper prop of the same design youre using now to help performance in any way.
PCM 351w, 350hp Last edited by TRBenj; 04-26-2012 at 11:03 AM. |
#25
Will I get more speed out of a 3 or 4 blade?
I don't want to have a footin prop and a slalom prop and I need one that holds speed in a course like my 4 blade.
#26
As I said earlier, a higher pitch prop will not help the overall performance, no matter who makes it.
#27
Eric, I do not believe the blade thickness was the concern. The speculation was that the shape of the XMP blade may have been more sensitive to flex at higher (prop) rpm's.
Im not sure what else would explain the phenomena that we're describing here, but feel free to enlighten me! Like Kyle, he saw the last 300-400rpm add little to no speed. Where are those extra RPM's going if theyre not pushing the boat any faster? Kyle, in theory, the fewer the blades, the more efficient the prop. Ive found the 3-blades Ive run to be a bit faster than the 4's. I think that the large blade surface area found on the modern CNC props largely levels the playing field between 3 and 4-blades, at least for applications with relatively low loads (skiing and footing). If youre show skiing or running a wakeboat with 2k lbs of ballast, I hear the 4's still do better for the big loads, especially out of the hole.
PCM 351w, 350hp |
#28
Acme vs. OJ XMP 13x12 3 Blade Prop Comparison From the article: The Acme has an approximate blade size of 8 3/16” across the blade (vertical in the picture) and 5 1/8” from hub to the edge of the blade. At first glance, the surface area of the blades appears larger on the Acme. From my measurements, it appears that the Acme has about 1” on the OJ on the vertical blade measurement. From hub to edge, they are about the same. The OJ has an approximate blade size of 7 3/16” across the blade and 5 1/8” from hub to the edge of the blade.
Previous: 1993 Prostar 205 Red 1998 Closed Bow Ski Boat, Ford 351, 310 hp, Acme 4 blade, Perfect Pass SG. FAQ Tyler Ski Club To me, this forum is about love of inboard boats. It is about the sharing of information and, on a good day, some humor. It is not about post count, brand of boat, or any other superfluous labels that lend themselves to a false sense of superiority. Please, respect one another, try to pass on accurate information, and keep your eye on the ball. Last edited by east tx skier; 04-26-2012 at 12:44 PM. |
#29
Doug, youre absolutely right- so far as Im aware, the CNC manufacturing process used on the Acmes and OJ XMP's is not the reason for the large blade surface area. Nonetheless, both CNC props do have a lot more blade surface area as compared to their conventional hand finished counterparts. Youre right that the Acme has more surface area, but the XMP isnt that far behind.
This is a new-ish hand finished OJ for comparison. As you can see, the XMP vs. Legend props are very different in shape, with the hand finished prop having quite a bit less surface area.
PCM 351w, 350hp Last edited by TRBenj; 04-26-2012 at 01:46 PM. |
#30
Tim - I see the last 200 - 300 RPM not gain much MPH with any prop regardless of who built it. The blade shapes are much different. The other is a more tradtional work boat type shape while ours is not that style. There are may other differences as well, rake and pitch distribution to name two.
Blade thickness is a major factor in top end. A thinner cross section IS faster. I used to thin my tunnel boat props to the point of breaking, in fact they would break and not last very long at all but I could thin a few more MPH put of it. When one of those props breaks you can end up upside down under water. Thin to win we used to say. Last I looked these boats were nowhere near 100 MPH nor do they have numbers on the side. As I said we prefer to build a good all around propeller that will last. The RPM we see on the ski boats should not cause deflection at all. We still run our "old style" 3-blades on flatbottom v-drives with overdrive transmissions, prop turning faster than engine RPM, turning 5500 to 6500 RPM with no flex issues. You will see more load and pressure on blades with the wakeboats loaded to the gills than you do with a 1:1 turning 5000 wide open Our current XMP 3-blades do have a different shape, even from our 4-blades. I built the prop pictured, 13 X 13 RC, in 1990 specifically for the CC boat. The blade shape I used was from a wooden pattern originally designed by my great grandfather Oscar in the late 1940's for racing applications.
Eric Johnson Johnson Propeller Co., Inc OJ PROPS 800-359-9730 Last edited by EJ OJPROP; 04-26-2012 at 01:55 PM. |
