  #51
Old 04-20-2012, 03:25 PM
JMann's Avatar
JMann JMann is offline
Boat: 1991 Prostar 190, Indmar 351
Send a message via Yahoo to JMann
Thanks for the replies. It sounds pretty simple. I will give it a shot probably should be done in the water and not in the drive way?
Old 04-20-2012, 03:40 PM
glgisler's Avatar
glgisler glgisler is offline
Boat: 1993 ProStar S&S
Carb kit
Skidim does have the 4160 Holley carb kit. It is Rn0120-1, at least for the Holley on the 351. for $50. You can also buy gaskets for the metering block and fuel bowl separately from http://www.holley.com/0-80319-1.asp, and maybe also from Skidim. Holley also has the complete carburetor and a kit, but I didn't check the price.
Old 04-20-2012, 03:49 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Yes, I would do it on the water as it will be running for awhile...
/spôrk/
Old 08-29-2017, 09:07 AM
Star Star is offline
Boat: Mastercraft Tristar
size o rings?
Originally Posted by heath124 View Post
Sorry for the confusion. I guess everyones ASAP is different from mine. If you ever see it in my post the wife and kids are sitting in the truck waiting on me to fix the boat or Im stuck in the middle of the lake needing info. I was under the impression you were trying to go to the water right then and your day was done over 2 O-rings.
What size 0 rings do I need for the fuel tube rings?
Old 08-29-2017, 05:18 PM
JMann's Avatar
I don't know, I ended up buying a carb rebuild kit and rebuilding the carb with a friend that knew what he was doing.
Someone here will be able to chime in and tell you I'm sure.
Old 08-29-2017, 06:23 PM
Just take the transfer tube with you to the hardware store.
Old 08-30-2017, 11:48 AM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 ProSport 205, 351 - 285HO
Hi Peter - been a couple of years since I went through this, but the front bowl needs to be removed to get the tube out, correct? If so, the bowl gasket should be replaced? Just asking to provide more detail for the process for replacment. Jack.
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 08-30-2017, 01:24 PM
Yes, you need to remove a fuel bowl- doesn't matter which one. If you have blue fuel gaskets, they are reusable. If not, you will need new fuel bowl gaskets. If you remove the primary fuel bowl, you will also have to ensure the accelerator pump arm ends up in the proper location. I use a dab of dielectric grease on the o-rings to keep them from getting caught and torn.
O'Reilly auto parts is pretty good at getting the correct parts for you.
Custom wheel and tire packages
Rebuilding Holley Carbs $289
Rebuilt complete Holley Carbs $425
1991 ps 190, carb, fuel problem, indmar
