#41
Speak up now if you want one! I'm going to have a custom one made from billet aluminum! Cost should be around $40...... |
#42
I know you are happy with the sub. Just put a 12 inch L7 in our 84 S&S this weekend. It is in a ported box and driven by an MTX amp. The port points out from under the drivers dash right at your business. The system sounds fantastic in the driveway. Cant wait to get it on the water and jam some tunes while giving someone a pull through the course.
#43
#44
very nice. i was actually just looking around and found that you installed the same system i just ordered!! I'm glad those kicker mt60 sound that good i was a little worried, with all the wet sounds hype you start getting caught up in it. that looks great.
2012 MC X-25 |
#45
Looks good. Clean install. I'd like to see what it sounds like out in the open.
#46
how did you get your amps installed on the side. on my x-10 its the hull on that side?
2012 MC X-25 |
#47
There's an amp rack there. Essentially a wood board, covered in carpet and screwed into the back of the rub rail. L-brackets mount the bottom to the floor.....
#48
Is that a capacitor I see there? How big did you go? How are the optima batteries working out. I went with the mb quart onyx4 125 per ch and a 600.1 mono for sub. That should give me 250 watts for the kt 60 towers I bought
2012 MC X-25 |
#49
I believe its a 1 farad cap...... Optimas work great! I play the stereo all I want and simply switch between batteries a few times daily to charge them. Periodically, I will put them on a trickle charger in storage.....
#50
I wanted to mention that the Alpine bluetooth remotes arent really waterproof. I had one on my shorts while surfing last weekend. It got water logged and got stuck onto + volume . I hope I didnt damage my speakers. Took a few minutes to get it shut off........ Very upsetting..
Thread Tools | |
Display Modes | |
