Old 04-16-2012, 11:16 AM
mtajpa's Avatar
mtajpa mtajpa is offline
One may be a ground connection that goes to the filler neck. It would be a green wire I think.
99 MariStar 230 Sport LTR 330
Old 04-16-2012, 02:42 PM
emnesto emnesto is offline
Boat: 2006 X45 LQ9
I believe all 3 relays are the same part. I just tried one of the other ones in the fuel pump position. Facing my LQ9 engine, the fuel pump relay was on the left.
2006 X-45 LQ9
2005 Yukon Denali
Old 04-16-2012, 03:39 PM
going to give that a try
Old 04-17-2012, 06:49 PM
Relays click, voltage on 1 click over reads 12v for several seconds and then goes to 0 (seems like should do that since it's priming) Of course the pump makes no noise.
If i wanted to tackle the fuel pump replacement (just the pump not the whole module) Is this the pump i should get? I read like 30 threads and i think this is it:
http://www.autozone.com/autozone/par...ntifier=386055
Old 04-17-2012, 07:18 PM
rhsprostar's Avatar
rhsprostar rhsprostar is offline
Boat: 04 TT 197
Yup that one will do nicely. You could also go with the E2065 pretty much the same specs. I used that one three years ago on my LQ9, and it has been perfect.
But before you do, what year is your boat? It doesn't really seem to be a problem as much on the newer boats.
Have a look at this post:
http://www.mastercraft.com/teamtalk/...ad.php?t=24965
04 197 TT LQ9 stargazer w/Z-Box
PB 1@35off
Previous...
96 Prostar 205 Lt1
93 Prostar 205 HO
81 Leaves and stripes(Can. edition)
Old 04-17-2012, 07:20 PM
2006 X1 with mcx engine
Old 04-17-2012, 07:28 PM
Jeff d Jeff d is offline
Boat: None
If you're not in a huge rush rockauto.com has the E2065 on sale for like $37 shipped. At that price I'm wondering if I should buy one just to have on hand.
Old 04-17-2012, 07:31 PM
Boat: None
Oh and I think that the e2044 and the e2065 are the same pumps but just with different o rings and mounting clips included for some other specific applications. I don't think you'll use those parts anyway so the part numbers are effectively interchangeable.
Old 04-17-2012, 07:44 PM
thanks just ordered it. hopefully it will save me some $$$
Old 04-17-2012, 08:36 PM
rhsprostar's Avatar
Boat: 04 TT 197
I think that 06's were still affected by the issue.
Good luck with the swap out Let us know if you need any help with the install.
You commute with your boat if I remember right?
PB 1@35off
Previous...
96 Prostar 205 Lt1
93 Prostar 205 HO
