...how'd you deal with the fact that the oil filler breather hose is 5/8" but the nipple of the valve cover breather is 1/2". The result is too much slack to be taken up by a hose clamp.
I was expecting a direct fit when I bought these valve covers. What am I missing? These are the Ford Racing cast covers by the way. ![]() ![]() ![]() |
Not sure if you can find a hose 1/2" on one end and 5/8" on the other, but try a 1/2" hose and heat the one end with a heat gun to slide it over the 5/8" breather.
Or take a 5/8" drill bit and drill one end bigger if the 1/2" hose is thick enough.
I was njskier on here. |
It didn't end well! |
You need something like this here. They come in alomst any combo you can think of. You can get a 5/8" to 1/2" reducer pretty easy.
http://www.fastenal.com/web/products...-131280&ucst=t |
http://www.uline.com/Product/Detail/...FQIBQAod1jsRgQ
Well, I no longer feel like the only idiot that thought of that and found out how quickly it doesn't work.
Just change out the breather cheap $6 and easy...Mr. gasket makes a one with a larger 5/8" nipple, I ran through the same thing with the ford racing version breather that came with my valve covers from ford last year...
http://store.prestoliteperformance.c...v-fitting.html
James 1989 MasterCraft TriStar 190 SE Last edited by j.mccreight@hotmail.com; 04-16-2012 at 08:30 AM. |
