gel coat repair
Don't know if you will be able to tell from these pictures, but does anyone have any opinions on how hard of a gel coat repair this would be for someone that doesn't specialize in gel coat repairs? Thanks in advance for any assistance.
Buy a gel coat repair kit and do it yourself.
What he said. Easy.
Are those hinges causing the damage? If so, you may want to deal with that before any repair.
not the hinges, but the gas tubes that support the motor cover must be going or have gone bad causing the hinges to make contact
2002 Maristar 230 VRS |
This would happen when the actuator for the hatch has been removed and only using the little ram to hold the hatch up. When you trailer like this the wind will get under the deck and cause it to open and break the ram and go over backwards damaging the gel. How do I know?
![]() I have yet to repair mine. However I did reconnect and use the actuator from now on.
99 MariStar 230 Sport LTR 330 |
Heres a start for you..
sand affected area flush as can be, clean area with acetone Add desired amount of gel, you can get self contained sprayer from Home Depot, http://www.homedepot.com/buy/preval-...un-317340.html http://www.iboats.com/Mastercraft-19...view_id.830245 then spray this over repair after desired amount of gel has been added to cure http://www.iboats.com/Evercoat-PVA-M...-view_id.38141 wait till dry, figure an hour.. clean off PVA with water.. wetsand w 400 then 200 grit.. polish with buffer and compound.......... smile
2002 Maristar 230 VRS Last edited by timvan; 03-03-2012 at 09:01 AM. |
this is much more low tech, but for small areas like that i use a product called marinetex. certainly not as glamorous as whats posted above, but cheap, easy and functional.
Here you go, use this:
http://www.spectrumcolor.com/Product...553902K&key=it At the bottom is the DIY for the patch paste kit linked above: http://www.spectrumcolor.com/TechnicalInfo.aspx |
#10
Yeah - do it yourself.. do you have the color name? Spectrum has small jars of gel to match.
