One question for you holman, In France this is illegal to transport LPG tanks to fill them in a car fuel station, altough there is no LPG stations on water of course... I never had troubles with cops but id. Every boater was running LPG the authorities would come in the problem...how is the law in NL?
#12
Running a large V-8 boat engine on LPG (propane) is entirely possible but not economical in my opinion. In addition to the cost of converting the engine to run on propane, you have the hassle of trying to find the fuel; not many marinas have propane filling stations located at the dock.
Propane and butane are extracted from the oil and gas produced from wells, nearly all of it extracted from the gas phase. With the increase in North America gas production due to fracing there is more propane available and the price of propane has dropped considerably since it peaked in 2008. When comparing the cost per gallon for the fuel you have to consider that propane has nearly 25% less energy per gallon than that of pure gasoline, so your consumption in GPH will go up. The ethanol / gasoline mix that most of us have to use has about 3% less energy density than pure gasoline. Propane is stored in pressurised containers to keep it liquefied. It must be a vapor to burn in your engine. It is easy to vaporize propane when it is hot outside and the flowrate of propane is small. But when it gets cold or the flowrate gets too high, you will also need a vaporizer to generate enough propane vapor to run your engine. A heat exchanger using engine cooling water would probably be sufficient. Nothing beats gasoline as a fuel for our size boats at the moment. Diesel is an acceptable alternative but not common. If you do make the LPG conversion let us all know how it works out for you. |
#13
we can transport 330ltr in original transportable LPG tanks,...but the tanks has to be secured to the vehicle.
Question for Fab,...how do the indoor forklift trucks refuel their tanks?...or are they all diesel,..even if used idoors? |
#14
have a few sets with some buddy,s...then do the math. |
#15
Well i always saw indoor forklift using "domestic" gaz tanks, like the ones you can use for your kitchen for cooking for exemple ! When the tank is empty you just give it back to the station and take a new one, you don't have the same stuff in NL...LPG tanks for cars have to secured in the vehicle as yours...As it's illegal to carry more than 20L of fuel in jerrycan in your car, it's illegal to carry LPG tanks from boat to station...Stupid thing because we have no solution but to do it...Most of lakes/rivers in France don't have fuel station on water...
And i agree with you holman with the cost balance...The difference between gas and LPG is so huge here in Europe, in only one summer the conversion advantageous... In france : Gas : 1.50€/L LPG : 0.8€/L How much in NL ? |
#16
LPG for my tank at home is about $1.75/gal and gasoline will likely hit $4 / gal this week. LPG will drop when heating season is over, too.
What is the cost to convert a 5.7 L TBI engine? Trying to figure out break even point? Sent from my PB99400 using Tapatalk
Everyone Dies, but not everyone lives ![]() 2004 Prostar 197, ACME 843 |
#17
Your engine will do with a impco model e vaporizer and a 425 mixer and those are cheap in the usa
#18
Need a little more info
This sounds very interesting. Can you describe how these parts are incorporated and how the tanks get mounted.
#19
Sorry about the Jack Johnny Lots of good info in the link Fab posted.Last edited by Shooter McKevin; 02-29-2012 at 02:04 PM. |
#20
Edit: accidentally did the electricity calculation. Since I can't delete this post I corrected it, but now it seems wrong. Maybe because of the efficiency of an electric motor over internal combustion? Charging an electric car (or boat) is not very cheap at all if this is anywhere close to accurate.
Obtained from the internet... 1kWh of electricity = 3.6 megajoules 1 gallon of gasoline = 130 megajoules So assuming the energy is extracted at equal efficiency (I have no idea if it is) equal energy of electricity (at $0.08/kWh) to 1 gallon of gasoline would cost $2.89 Or compared to 1 litre of gasoline $0.76 (we pay roughly $1.00 - $1.20/litre here) Last edited by Shooter McKevin; 02-29-2012 at 02:16 PM. |
