  #1211
Old 01-02-2012, 12:07 AM
JMann's Avatar
JMann JMann is offline
Boat: 1991 Prostar 190, Indmar 351
Send a message via Yahoo to JMann
I removed the right exhaust riser and hoses. Before I reinstall I need to know how much I need to clean the riser and manifold. Do I need to clean all this dark muck and rust off the surface it's hard and didn't want to come off. I would need to steel wool, wire brush or file it off. Do you think this is clean enough or do I need to clean this all the way down to shiny metal?
Old 01-02-2012, 01:09 AM
mart_it's Avatar
mart_it mart_it is offline
Boat: Prostar 190
I've seen risers on this site a lot worse than yours are!....I would leave them ''as is'', of course you could spend 100+hours cleaning the insides to get them to look like new but that wouldn't lead to them functioning that much better.
Only thing I would do is sand the mating surface with a polishing disc before re-installing gaskets.
Old 01-02-2012, 01:40 AM
JMann's Avatar
That was my questions do I need to clean the mating surfaces on the exhaust manifold and exhaust riser smooth before I put them back together? I tried with a wire brush and steel wool and this is as clean as I could get the riser surface after 15 minutes? Should I go cleaner or will the gaskets seal it, the mating surface defenitely isn't smooth.
Old 01-02-2012, 07:54 AM
John 3:16-18
Old 01-02-2012, 01:57 PM
JMann's Avatar
Thanks Cloaked. I will get out the sanding block and 120 paper and get to work. I still have to do the manifold side too.
Old 01-02-2012, 02:42 PM
BrooksfamX2's Avatar
Boat: 2007 X2
Permatex (and several others) make a spray on gasket remover.
http://www.permatex.com/products/Aut...et_Remover.htm
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 01-02-2012, 06:22 PM
ctjahn ctjahn is offline
Boat: Own a 78 MC S&S
priming trailer
Finished priming the trailer.... Next up paint.... this is after hours of wire brushing, sanding, and scraping - (Just by brush but I dont have a place to put the boat off the trailer nor the means to lift it off... Ideally I would have removed the boat, blasted and powdercoated)
If anything its been a good workout!
Cj
78 S&S green over green
Old 01-02-2012, 06:30 PM
Cj
No pics..........
Old 01-02-2012, 06:56 PM
214skier's Avatar
214skier 214skier is offline
Boat: Current: 2014 PROSTAR 214v ~ Former: 2010 X14v | 1997 PS190 w/ LT1
Installation of latch for cooler locker
My 2010 X-14v did not come with the (now standard) latch for the cooler locker. I had ordered one from MC this Summer and finally got around to installing today. What a convenient feature! Easy access to the cooler, grabbing multiple cold ones for friends!
Old 01-02-2012, 07:07 PM
Well, uh....
No pics..........
Wife's sister has the camera....
