LT-1 items 1996 PS 190
New to me, 480hr 1996 Prostar 190 LT-1. I am just trying to get my maintenance items together. I have gathered bits of info from other threads someone please confirm I am correct on these replacement items for the 96 LT-1:
Oil-synthetic 20w-50 (boat runs in Minnesota waters) Spark plugs- AC MR43LTS gap (.045?????) Fuel Filter- AC GF-626 Oil Filter- ???????????????? Thank you |
Oil Filter – WIX 51061
Fuel Filer – WIX 33481 Fuel Filter (on tank) – WIX 33003(clear plastic) or 33482(metal) Edit: And yes, AC MR43LTS @ .045" Last edited by Table Rocker; 09-17-2011 at 10:36 AM. |
should not have to do much... change the oil. and fuel filters.
1998 ProStar 205 LT1 |
I usually spare no expense when it comes to my boat, but I do cheap out on the oil. I just run a good quality 20W50 petroleum based oil and change it out about every 50 hours.
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
15W40 diesel oil is more than acceptable as well.
Napa Wix 51069 or 1069 oil filter. What is the 51061? A larger filter?
Damn, just bought a 1069 today.
Oh well, only got 25hrs on the boat this yr anyway, don't need a better filter. ![]()
| Tags |
| lt-1, tune up |
