Old 08-18-2011, 09:16 PM
jvbaca's Avatar
jvbaca jvbaca is offline
Boat: Mastercraft X-45, 2005
On my '05 x45 it's in the same area as the center plug, just unscrew the round cap on the deck (under the carpet) and it should be right there.
Old 09-09-2011, 10:04 AM
smilemaker smilemaker is offline
Boat: Mastercraft X-45 2006 LY6
I was able to replace the Fwd pump and works fine. The circuit breaker keep going bad on me, maybe they only last 5 years? Thanks with all the help and advice.
Old 09-09-2011, 07:14 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
If the breaker keeps blowing, either the breaker is bad like you said or there's a short in the wiring somewhere.
If you can trace the wires you can see, check for damage causing a short.
COnsidering the breaker is easy to replace and not very expensive, I'd try that second. If that doesn't work then considering there are parts of the wire you can't see, just use the old wire to pull some new wire from the pump to the panel. likely a damaged spot.
'06 X2 MCX
bilge, speed control
