Surfing a 2000 Pro Star 205 DD
Tring to set up a good wake on my boat. I have a 900# bag in the rear, a 350# bag in the ski locker, and 2 350# bags on the surf side. I'm thinking a bow sac under the seats may be next. The wake looks good but I still can't surf(I'm 250#). My buddy who is half my size can though. Anyone else surf a 205 or have any suggestions?
I may need a different board. We are using a Hyperlite Broadcast. |
I have 1997 205, same as your hull, I'm about 210 and can surf with no ballast with a 7 ft ocean board, I did modify my platform to fix it from digging into wake, this was probably the most beneficial mod. We also use three 30 gal trash cans for ballast and get a nice wake, low budget operation but it works.
Let's see some pics of that swim platform.
I have a 97 ps 205. I put 750# under rear seat shifted all the way to the port side, and 750# down the port side of the engine. The two bags make an L-shape. The rub rail is right at the water line when loaded down. I get a wave that comes up to my hip with a nice curl when I drive about 10.5mph. I think I'm gonna try pulling off my swim deck next time I'm out to see if it cleans it up even more. I think it is acting like a trim tab and lifting the port corner out of the water a little as we drive. My friends and I are all around 200# and can easily surf on any of the boards out there on this wave. My mother in law said it is much bigger than the wave they surf behind a friends x-30 with stock ballast.
tom
1997 Prostar 205, LT1 powerslot I carry a gun because a cop is too heavy |
platform
My platform was repaired by previous owner, they had the wrong angle, i made the wooden shim. now it is slightly above stock. Now it never digs into the wake. I am also using 7 ft ocean surf board I bought second hand. We can surf no ballast or if we want to use our 5'6'' liquid force board we will fill up the three trash cans. Fixing the platform angle fixed everything. I noticed your mudbug name, you must be Shreveport area, we are in Ruston, we usually goto Claibourne.
I have not tried putting any fat sacks up front yet. I have moved people around in the boat and haven't found a huge difference. The biggest thing is just keeping all the weight to the port side. I think removing the swim step will make a big difference though. |
unfortunately removing the platform is illegal here in MA(like everything else) so i cant do that. i may make a smaller one or was thinking about making mine on adjustable bracket so i can change the angle when surfing.
I would say you need a bigger board unless you have the 5'6" broadcast. I would say 5'3" or bigger for you weight, unless you have a really big wave. Preferably 5'6".
#10
I have the 5'6" broadcast. I'm currently looking at some other "surf constuction" boards for next year.
| Tags |
| 205, pro star 205, surfing, wakesurf, wakesurfing |
