Old 06-29-2011, 08:07 AM
Grantx15 Grantx15 is offline
Boat: Mastercraft X-15ss 6.0
FAIL!
once again the patch job didnt hold. since its impossible to replace the KGB with out splitting the boat. has any one every cut out the polly tanks and replaced them with fat sacks???
this is my next option.
Old 08-07-2011, 11:38 PM
Ortho Ortho is offline
Boat: 2013 Mastercraft X30
Grantx15-
Did you find a solution to your problem. I've got 2006 X15 with the same problem. I have tried at least 10 different epoxies, tank patch, glue etc. Nothing will stick to this plastic!
Old 08-08-2011, 02:16 AM
Desert eagle's Avatar
Desert eagle Desert eagle is offline
Boat: Master Craft, X25, 2011
I repaired a polly tank on a radiator reservoir for my RV this last winter and it is still holding up.
Get yourself a heat gun that will get hot enough to melt the polly, and weld the tank back together.
Old 08-08-2011, 02:31 AM
sand2snow22's Avatar
Boat: Ri257
Just make sure it is a ballast tank and not the gas tank
Old 08-08-2011, 09:12 AM
Jerseydave's Avatar
TT Hero
Grant try taking your boat to a radiator repair shop (Fingers radiator on route 130 maybe?) and see if they can repair it right in the boat. I'd hate to see you cut-out that tank but I guess that's a last resort.
I was njskier on here.
Old 04-19-2013, 02:46 PM
c640947's Avatar
c640947 c640947 is offline
Boat: temporarily boatless
I would like to revive this thread as my 06 X2 is leaking in the exact same spot and I have tired a couple of different options to seal the crack with the same results as the original poster. Has anyone managed to fix a leaking KGB tank? Or have any suggestions that are different than what was already tried?
Andrew
Current:
Previous Boats:
2006 Mastercraft X2
1995 Mastercraft ProStar 190, New Dimension Tower
1990 Supra Conbrio
http://www.tigerboatdocks.com
Old 04-19-2013, 04:03 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I friend of mine had his 07 tank start leaking about 3 or 4 years ago. The dealership had his floor marked up to cut into it to repair the crack. At the last minute, they went another route. They had a guy come in and plastic weld it. I'm sure if you called around, you could find someone in your area who has the tools to weld polyethylene tanks. He just sold the boat a couple of weeks ago, and it was still holding strong.
Old 07-22-2013, 08:02 AM
Bungee55 Bungee55 is offline
Boat: 1992 Prostar 205, 2008 Xstar
Old 07-22-2013, 09:32 AM
Hrkdrivr's Avatar
Hrkdrivr Hrkdrivr is offline
Boat: MasterCraft X-45, 2006, L18, slate gray/white
duplicate post
2006 X-45, L18, slate gray/white
Old 07-22-2013, 09:34 AM
Hrkdrivr's Avatar
Bungee55, wow! Amazing piece of engineering, but, wow!
Who fabricated the piece? Did it work?
