Old 07-14-2011, 01:58 AM
RMUDBUGS RMUDBUGS is offline
Boat: 2000 Prostar 205
Installing a new prop?
I got a new prop from Eric at OJ props. I have never installed one before so. What do I need to know? Thanks
Old 07-14-2011, 08:04 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
First thing you need to know is whether you have a tapered shaft or splined shaft.
'04 MariStar 230VRS/MCX
Old 07-14-2011, 11:31 AM
Tapered shaft
Old 07-14-2011, 11:44 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Here is the procedure in an older owner's manual. To be honest, I have not checked the contact area between my prop hub and the shaft (didn't know about this until after I had been running the current prop for a few years). But I know others who do. May tackle it as a small winter project.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
O2BESOHUGE's Avatar
O2BESOHUGE O2BESOHUGE is offline
Boat: 1991 MASTERCRAFT PRO STAR 190
i had to get a torch to heat my old one off...without heat my prop wouldnt even budge!! i heated it up and tapped it with hammer and it fell off into my hands
but then....
i got on here and bought a prop puller and it was easy as cake. i wish i had known about this board before then!
Old 07-14-2011, 11:47 AM
jdl xstar's Avatar
jdl xstar jdl xstar is offline
Boat: none at moment
Once you remove the cotter pin and nut, i take a 2 x4 and use it as the buffer/pressure distributer behind the base of the prop as i tap it with a hammer. It usually pops off after a few firm taps.
Tight fit between rudder and the shaft so it will take some maneuvering but you'll find that angle where the prop will come right out.
Slide on new prop, tighten nut firmly, and replace with a new STAINLESS steel cotter pin.
Previous - 2007 X-Star w/ 8.1l
Previous - 2007 X2 w/ MCX
Old 07-14-2011, 11:49 AM
You'll likely want a puller to facilitate getting the prop off.
Inboard Propeller installation procedureInboard propeller installation procedure
Push propeller snugly onto shaft taper WITHOUT key in either keyway (propeller or shaft)
Make sure the propeller is snug and there is no side to side movement by gently moving propeller back and forth.
Make a line on the shaft with a non-graphite marker at the forward end of the propeller where it stops up against the shaft taper.
Remove propeller.
Put key into keyway on shaft taper with radiused or chamfered corners (down) in shaft keyway (if propeller shaft keyway has radiused corners).
Put propeller onto shaft taper.
Check to see that the propeller moves back to the forward line made in Step 3. If it does, skip down to Step 8. If not, perform the following:
A: Remove propeller from shaft.
B: Place a file on a flat surface area or work bench.
C: Run opposite end of chamfered key back and forth over file (to remove any burs) with a downward pressure on key until side being filed is clean.
D: Install cleaned key in shaft keyway with chamfered corner side down in shaft (the cleaned, filed side up in keyway).
E: Replace the propeller on the shaft and fit snugly on taper. Check to see if it reaches the line make as in Step 7. If it does not line up than repeat "Steps a. through e".
NOTE: A vice can be used to hold key and then filed, but care must be taken not to tighten too much, causing burrs and irregularities on key.
8. When propeller hub moves to correct position, install propeller nut on shaft and torque to seat the propeller. Install the torque jam nut also, if your shaft is so equipped. Install cotter pin at end of the shaft.
Correct Nut Instaltation Procedure: Install Jam Nut (thin) first than the Full nut (thick) goes on second.
Old 07-14-2011, 02:32 PM
Thanks
I bought the spare prop kit that comes with the puller at the same time that I bought the prop.
Old 07-14-2011, 02:45 PM
jbkriss's Avatar
jbkriss jbkriss is offline
Boat: 2014 X10
Can't get my prop off
I tried to get mine off the other day (keyed) with a prop puller and it still wouldn't budge. I'll try heat like mentioned above. Any other pointers? Thanks.
Old 07-14-2011, 04:53 PM
O2BESOHUGE's Avatar
Yeah, Next Time You Put The New One On, Grease It Before You Put It On. That Way It Wont Stick As Bad Getting It Off Next Time If You Have To
