04 X9 Ballast Automaticall Filling
I just started encountering an issue with my factory hull ballast where it is automatically filling up while in the water. I drain it completely, ballast pumps are turned off (they are definitely not on and even disconnected the battery to assure), and next day the bag is full.
Anyone seen this problem and have a resolution. Usually the issue is with priming/filling ballast, so a reverse issue. Thanks in advance! |
Green impellers. Your old impellers are allowing siphoning of water into the tanks. Replace them with green and you'll be good
| Tags |
| automatic, ballast, filling |
