Old 05-17-2011, 03:43 PM
hadzinak hadzinak is offline
Boat: X-2SS 2007
Send a message via MSN to hadzinak
broken prop shaft
My prop shaft broke for the second time on the couple side just after the coupler....
Old 05-17-2011, 03:47 PM
DooSPX's Avatar
DooSPX DooSPX is offline
OUCH!! How in the world did you break a shaft? Hit something with some force?
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 05-17-2011, 04:27 PM
muskingumriverdocks's Avatar
muskingumriverdocks muskingumriverdocks is offline
Boat: 1974 & 1976 MasterCraft Stars and Stripes
Sounds like it's misaligned. Happened to my '74 SS once when the rubber came out of one motor mount.
Old 05-17-2011, 04:47 PM
Boat: X-2SS 2007
misalignement...
Old 05-17-2011, 04:56 PM
DooSPX's Avatar
ouch!!!! I'm sure your strut bushing needs replacing and possibly even the strut it self?
Old 05-17-2011, 05:36 PM
ahhudgins's Avatar
Originally Posted by hadzinak View Post
misalignement...
Who's doing the alignment? When I purchased my last used MC it had a bent strut. When I disconnected the coupling at the transmission, the shaft was a good 1/4 inch out of alignment due to the previous owner driving around with a bent strut. How far out of alignment do you have to be in order to actually snap a shaft in half????
Old 05-17-2011, 05:43 PM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
If the shaft is out of alignment, it will create cyclical loading bending forces on the shaft as the shaft rotates. The more times the shaft rotates, the more load cycles the shaft goes through. Each loading cycle causes metal fatigue, and eventually a crack will develop and the shaft will fail.
I would think there would be some noticeable vibrations to go along with the misalignment long before the shaft failed, though.
2002 X-Star w/ LTR
Old 05-18-2011, 12:31 AM
Boat: X-2SS 2007
it felt as if I was in an old truck as far as the vibrations go... The shaft snapped when I put it in reverse to park the boat. As far as I can see the bushing was good and the strut didn't have any visible problem. The lower broken part was rotating smoothly through the bushing/strut... Does a machine exist that can align the shaft or is it done manually ?
Old 05-18-2011, 01:46 AM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
That's a nice pry bar ya got there!
Seriously, don't throw away the old prop shaft. There is NOTHING better to use when trying to push around the engine and trans when aligning them to the prop shaft... nothing ( ;
Need LT-1 parts?
89058397 (pump outlet side)
Old 05-18-2011, 12:06 PM
G-Star's Avatar
You are ze machine.
There are a couple good threads that describe the procedure... this one should help:
http://www.mastercraft.com/teamtalk/...ment+procedure
Also, there's a good document that describes the whole procedure. I managed to find and attach it.
2002 X-Star w/ LTR
