JL Audio Problems
I have a 2006 X-Star with the standard 6 interior speakers, sub, and 2 tower speakers. For some reason I have been losing speakers left and right. They started going out on the port side, and now I'm left with just one of the tower speakers, sub, and speaker right behind the driver. They have been going out one by one...very strange. Has anyone had this problem or know any tricks to fix it? I'm pretty knowledgable with sound systems, but this has me stumped.
Thank you! |
If you switch speaker wire connections at the amps, do the working speakers stay the same or correspond to speaker ports on your amps?
2008 X star, 2005 X2 |
I just messed around with it. I moved connections around and everything. Now I just have one tower speaker, no sub, and one interior speaker...one that wasn't working before. It seems as if the problems are getting worse.
Did the OP get an answer to his losing speaker issue. I have the same proble
My 2 bow speakers and one behind the driver. I am not good with sound systems and no one within 60 miles has a audio shop to take to.
David 2008 X2 MCX ![]() 1999 Maristar 210 (sold) 1996 Bayliner 2050 |
It can be tracked down and isolated by doing what Vision suggested. If only one channel (speaker port) is working then its an amp issue. If none of the other speakers will work on that same channel that plays then its a speaker issue.
| Tags |
| audio, problems, speakers |
