Prepping trailer fenders for paint
How would I go about getting my fenders ready for paint? Wetsand? Going to use this paint. The finish on my fenders is bad enough that I don't think they can be brought back.
-Aaron 1996 RED Prostar 205 |
Tim Gone, surfing. |
Yup, before You paint it will need to have any cracks or imperfections repaired and sanded smooth in steps up to 320 grit. Then primer needs to be layed down and block sanded smooth in steps up to 320 grit and then wet sand with 500 grit before you lay down top coat and the clear coat. Its a LOT of work to paint those fenders to achieve a nice looking finish... so I would also recommend wetsanding the gelcoat first just to try bringing them back.
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) Last edited by JLeuck64; 03-22-2011 at 11:45 AM. |
Thanks for the replies guys. I will try to restore them first, but I believe I will probably have to end up painting.
**Thread Jack - Sorry**
While your there can you measure the running light knock out? For both the amber and red lights and how big the light is? My boat is in storage and it would save me a trip. ('97 single axle) |
Barefoot,
I would help you out but my boat is in storage until this weekend.
Do you have any pics of the fenders?
This.
When you get it out take some good photos and post them up. There are some pretty smart guys here that could offer up better options if you show us what you are up against. ![]()
WOW!
(wished my fenders looked that good...) ![]() My fenders have stress cracks, have damage to the tail light area, a tear from being side swiped in the parking lot and are a blue metal flake which is really hard to repair. looks like you will have an easy time making those look like new again!
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
| Tags |
| fenders, paint, trailer |
