Old 11-12-2010, 05:25 PM
Skipper's Avatar
Skipper Skipper is offline
Boat: 1995 MC Prostar 190
Fuel Sending Unit Repair
Late in the season, the fuel sending unit went out on my '95 Prostar. Somebody suggested that it could be fixed. Instead of fixing it, I purchased a new one for $160.00 plus shipping. I left the old one on my work bench....until today.
If you have this type of fuel sending unit, and it is inoperative, it is likely that the magnets have come dislodged from the foam float. It is a simple repair to get you back on the water.
There are three main components: The tube assembly, the circuit board, and the float. To disassemble the unit, remove the two screws at the bottom of the tube and remove the plastic cap. Then unscrew the two nuts at the top of the unit to allow the circuit board to slide out of the tube.
The culprit in my unit were the two magnets that are supposed to be lodged in the foam float. They came out of the float and were resting on the tab at the bottom of the circuit board. I just used some 5 minute epoxy to connect the magnets back into the float. Then I used a fine file to smooth out the repair.
I tested the unit by attaching an ohm meter to the circuit board, then moving the float. You can see in the next pictures that the reading on the guage changes as the float goes from the top (full) toward the bottom (empty).
Reassembly is just the reverse of disassembly. I cleaned everything up with WD-40 first. Just be sure to insert the foam float into the tube before pushing the circuit board all the way to the top or the tab at the bottom of the circuit board will prevent you from inserting the float. Once assembled, I tested the unit again, this time by holding it right side up and upside down. This just verified that the unit is back in action. You can also connect it to the fuel guage wires and (with the key on) turn it up and down to view the fuel guage changing.
Hope this helps somebody else in the future. I sure could have used that $160 some place else. This repair took only about 20 minutes and cost nothing.
1995 Prostar 190
Remember, we must share our waters and be respectful of other boaters. Rude people suck!
Old 11-12-2010, 05:41 PM
Boat: 1998 Maristar 200VRS
Thanks, Skipper, that's the best write-up I've seen on this.
I had to do the same to my boat 4 or 5 years ago; at that time, there were a few active threads on here about re-attaching the magnets. Haven't seen another mention since then.
/frank
Old 11-12-2010, 11:26 PM
wtrskr wtrskr is offline
Boat: '94 prostar 190
When I first purchased my 1994 prostar 190 this summer I attempted fixing mine. I reattached a magnet that was loose without any improvements. I think my problem is that the foam float gets stuck.
I may give mine another try next year after seeing that you were able to successfully fix yours.
Old 11-13-2010, 01:15 AM
I found the same as Skipper - I had to do some shaving of the float to get it to move smoothly without sticking.
Old 11-13-2010, 09:37 AM
Skipper's Avatar
There are two magnets. One goes on each end of the foam in the slot. If you have only one magnet, then it will not trigger the sensors in the circuit board. Using a fine file, I removed all of the epoxy covering the magnets on the foam and made the overall surface smoother.
1995 Prostar 190
Old 11-13-2010, 10:16 AM
Skipper's Avatar
The tube in my unit had some old fuel residue built up inside. I cleaned the tube and the circuit board with WD40. You can test the system by connecting to an ohm meter and moving the foam float across the back of the circuit board. The reading should change with the position of the float. If this works, then after you reassemble the unit turn it up and down and the foam float should fall freely. If it is cleaned up inside there should be nothing for it to hang up on in the tube. Also, be sure to file or sand down the front of the float where the magnets are closest to the circuit board. This will keep that surface smooth and will give the best interaction between the magnets and the circuit board.
1995 Prostar 190
Old 11-13-2010, 10:47 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Excellent walkthrough. I added it to the FAQ.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 12-09-2010, 07:15 AM
WTRSK1R's Avatar
WTRSK1R WTRSK1R is offline
Boat: 2004 MasterCraft ProStar 197
I used to have a 92 ProSport 205 and when reformulated fuel came to our area in the mid 90's I had the same issue with the foam getting stuck. I think it swelled slightly with whatever they add to the gas. Anyway, I was able to sand it down slightly all the way around the edges of the float and did not have any further issues with the float for the remainder of the time I had the boat.
Steve
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile
2004 Prostar 197 - Red on White
350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun!
Old 12-09-2010, 01:49 PM
JMann's Avatar
JMann JMann is offline
Boat: 1991 Prostar 190, Indmar 351
Send a message via Yahoo to JMann
I bought a new sending unit on skidim for $60. Seems a lot easier to replace than repair.
Either way thanks for the write up very informative.
Old 12-16-2010, 09:43 PM
mbeach mbeach is offline
Boat: 1998 sportstar 19
only trick to the repair is aligning the magnets so the poles repel each other. can test by taping magnets in place and sliding along the powered circuit board while watching the fuel gauge.
