On a more serious note, I think it would be worth your time to find out exactly where the leak is coming from. It may just be a loose hose connection, Leaking oil cooler, or input/output seal. Neither of those items would require a full on rebuild if the trans is working properly. Just fix the leak and return to service. One other thing... if you do happen to have a Hurth trans they have a plate on the bottom of the trans that holds the filter screen in place at the bottom of the reservoir. I found out mine was leaking (after everything was back in the boat of course!). That small rectangular plate is secured with four bolts and is only sealed with RTV. Very, very difficult to re-seal with the trans installed in the boat. Not impossible, but probably would have been easier to remove the trans to re-seal it. HTH
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#12
___________________________________________ ________________________________ |
| Tags |
| leak, rebuild, transmission |
