Old 08-30-2010, 06:01 PM
DavidMCX30's Avatar
DavidMCX30 DavidMCX30 is offline
Boat: 2002 MasterCraft X30
x30 exhuast manifold temp variences
Just bought a 2002 x-30 this spring and loving it! Weíve done a lot of work on the boat but here is one problem we haven't cracked....we blew out an impeller at Lake Wawasee a few weeks ago while on vacation. The folks at the marina -- whom I like and trust -- replaced the impeller and did the standard blowing out of hoses and whatnot. However, the temperature in my port manifold was still high Ė 160 degrees vs. 100 degrees on the starboard manifold. They went back in and rechecked twice more for obstructions but found none. We went round and round on what the cause could be, with lots of varying opinions from various dealers. Ultimately, they called Indmar and tech support told them this variance in manifold temperatures was OK. So, we chose to leave it alone. The boat seems to be running fine. But Iím still left wondering if it is OK or if I could be doing harm? Iíve searched the discussion board but havenít found this exact topic covered. Any thoughts? Thanks!
Old 08-30-2010, 08:49 PM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
I checked the manifolds on my 95 this summer because a poster had a similar question as yours. Using an infrared thermometer, the temperature varied at different points all over the manifolds and risers. My engine used the 143 degree thermostat (which I have since changed to the 160) and I got readings from 115 to 160 depending on exactly where I put the thermometer. Placing my hand on top of each riser, I can feel a little difference in the temperature. The only way to be 100% sure that you donít have a blockage is to remove the riser and check. Iím not a big fan of the compressed air method. If there was a piece of old impeller in the manifold water jacket, blowing air into may have only moved it around.
Old 08-30-2010, 09:49 PM
Boat: 93 190
John 3:16-18
Old 08-31-2010, 01:49 PM
DavidMCX30's Avatar
Thumbs up
Thanks for the great reply. If I place my hand on the riser, I can feel the difference as well. I said they blew out the hoses, but that was my language; I don't think they used an air compressor--or hope not based on your comments! As the Wawasee Boat Co. mechanic went in three times to make sure there were no obstructions, I feel reasonably comfortable they've cleaned everything out. Your experience with varying tempuratures up to 160 gives me better confidence that I am OK and that this is not completely uncommon. They thought the temperature issue might be a problem because their experience with CorrectCraft is that the temparatures are more uniform. across the manifolds. Thanks for the help.
Old 08-31-2010, 01:53 PM
DavidMCX30's Avatar
Thumbs up
I have had the same problem previously with the basic 351 engine.
One thing I learned from the fine folks at Discount Inboard Marine is their trick of the trade for testing the raw water pump for volume flow and, good impeller and housing integrity (wear plate and seals) is to get the engine running and rev it up to about 3k. Disconnect the thermostat end of the hose that comes directly out of the pump. It should fill a 5 gallon bucket in about 15 seconds. I tried this just this evening to see if it worked. Spot on for the 15 seconds, My pump is working fine. I have now eliminated that possibility of an issue I am dealing with. Saved me from rebuilding the pump unnecessarily. Good test. Next step now is to pull the riser from the mainfold and check the flow path there at the gasket. While the riser is off, I am replacing the exhaust hose going into the muffler. Those things are hard to replace without removing the riser. That 3" diameter hose is seriously stiff.
I think the marina did a similar test for me. They also put a clear hose on so they could see the water rate flowing through and to determine if there was too much air or other issues. I have to confess I'm fairly new to all of this, so I really have to rely on my mechanic and you guys at this point! Thanks for your insight.
Old 08-31-2010, 09:58 PM
Boat: 93 190
John 3:16-18
Old 09-02-2010, 01:28 PM
DavidMCX30's Avatar
Very interesting. Did it solve your problem? I am going to check my hoses. Great suggestion.
I guess my larger question is this: Is it OK to run with tempertatures of 160 on one side? based on what Indmar said and what I've read here, it seems like this variance might be normal. and it is OK. Your thoughts? Thansk again!
Old 09-03-2010, 10:10 PM
Boat: 93 190
Yes Sir. Problem solved. That was indeed the issue. The release of backpressure also cleared up one other performance issue as well. I ran it tonight on the water.
I consider Indmar to be Subject Matter Experts (SME) as well as the fine folks at Discount Inboard Marine. I was talking to Richard and Vince at DIM and they too said it is not unusual for one bank to run a bit hotter than the other is. I would not have an issue running the boat at 160 deg F.
One thing to consider (for me) my temp gauge was reading right at 160 deg F and the riser was very hot to touch. I knew the water was cooling the temp sensor but also knew I still had a problem. This is with a 143 deg F thermostat. Once I ran the engine tonight with the new hose, everything fell right into place. I am 100% confident that this resolved my issues after running it on the water. It idles much better, accelerates much better, etc.... sounds much better.
Be aware that to get to the hoses (easily) you'll need to remove the riser (or tangle with a stiff hose). In doing so, order a new gasket first and have it on hand. That said, with an 8 year old boat (no real age) while I had the riser off, I'd replace the hose(s) anyway since it is apart. That being, you may want to order two hoses and gaskets, and replace the other one this winter. Preventative maintenance. Don't forget the anti-seize compound on the new riser bolts that you will install. Eighty-grit sandpaper and a window scraper knife will clean the flange mating surfaces from the old gasket material. Some dishwashing soap allows the new stiff hose(s) to slip on easily.
The large opening is the opening between the wall and the interior ID. That is where the water was going and the other end of the collapse was not open. It was backwashing into the riser.
John 3:16-18
Old 09-07-2010, 10:58 AM
DavidMCX30's Avatar
Fantastic! Glad to hear that you've solved your issue. I think this type of repair sounds above my skill level, so I'm going to ask my mechanic to take a look. I'll print this thread so he can look at it. Thanks for all your insight. Have fun on the water!
Old 09-07-2010, 06:28 PM
Boat: 93 190
John 3:16-18
manifold, temperature, x30
