Old 08-23-2010, 09:32 PM
tcn18d
Posts: n/a
Lost Power to all accessories, blower, and bilge pumps
Hello Everyone,
I have a 2005 Mastercraft X2 with a 350. I've lost power to all lights, blower, and ballast pumps. Any hints on a fuse location or where I've lost power?
Appreciate the help,
Travis
Old 08-26-2010, 07:59 AM
bturner2 bturner2 is offline
Not sure about your boat but on my older boats there was a circuit breaker located on the engine. It's mounted on a bracket and has a red button. See if yours has one that has been tripped. Next would be to check the panel under the dash. There should be a set of breakers there. Past that you're going to need to start at the battery and start tracing the power to the dash.
Old 08-26-2010, 10:01 AM
CruisinGA's Avatar
CruisinGA CruisinGA is online now
Boat: '01 X9 330HP
Not sure bout your boat, but on my '02 x9 there is a circuit beaker mounted next to the batteries under the observer seat, if it was to trip I would lose power to all accessories.
Bailey
'02 X-9
Lake Blue Ridge
Old 08-26-2010, 10:57 AM
willyt's Avatar
willyt willyt is offline
Boat: 2007 xstar
I have the same boat
First, check your battery connections and make sure you're getting enough power (might be an alternator problem.... unlikely though). Once you've ruled that out the fuses for the ballast pumps should be the little rubber bubble that sticks out below them. Push those guys in and it should reset. the other fuses will be located under the dash. Let me know if that solves your problem
Old 08-26-2010, 11:13 AM
flipper's Avatar
flipper flipper is offline
Boat: 1991 Prostar 190, fuel injected 302
Sounds more like a ground wire to the dash to me. I wouldn't think it would blow all the fuses/breakers all at once on different things.
Lots of power is good, more is better, too much is just right.
'91 prostar 190
Old 08-26-2010, 11:45 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Ck the main ground coming from the dash to the battery. Also, should be a large fuse on the main + wire going from the battery to the dash....if it's similar to my 06.
'06 X2 MCX
Old 08-29-2010, 01:25 PM
tcn18d
Posts: n/a
Problem Solved
Hello Eveyone,
Thanks for all the tips and comments. I solved the problem this weekend, turns out that I had blown the main fuse going to the dash. Appreciate all the help!!
ballast, blower, lights, power, pumps
