Old 05-07-2010, 08:30 AM
79_SnS_atl's Avatar
79_SnS_atl 79_SnS_atl is offline
Boat: 1979 Stars and Stripes / 351 PCM
Nice Job. You confirmed my belief of using a urethane on top of gel coat.
Shadetree tip: I have had results equally as good with clear urethane from Minwax out of a can and if you roll it (yes, roll it) in thin enough coats with a soft sponge roller you will achieve the same effect without over spray and masking. It works for a quick fix and will enhance the metal flake as good as spraying it on. As you can see in my signature photo that is what my gel coat looked like before I did the clear.
Find more info on my latest project on FaceBook: http://www.facebook.com/group.php?gid=102832819752389
"Keeping the dream alive."
Old 05-07-2010, 12:32 PM
83SuperSlot's Avatar
83SuperSlot 83SuperSlot is offline
Boat: 1983 Stars & Stripes - SuperSlot 440 V8
do you have to wax over the urethane?? I think this is what I might do....
Old 05-09-2010, 10:50 AM
Bellinghamster's Avatar
Bellinghamster Bellinghamster is offline
Boat: 1978 Stars and Stripes, PCM 351 (60hrs)
Urethane clear is what's used on vehicles. It's pretty durable, and doesn't need waxing nearly as often as gelcoat if at all. I think the wax adds just a bit more gloss, probably more so after 10 years... it makes the water bead up, and may protect it from lake scum.
Old 05-09-2010, 11:02 AM
Is this the same clearcoat you can buy at autoparts stores in a spray can...
Old 05-09-2010, 09:42 PM
rsmith_5568's Avatar
rsmith_5568 rsmith_5568 is offline
Boat: Mastercraft prostar 190 1986 351 indmar power slot
looks good
Old 05-17-2010, 08:48 AM
Originally Posted by 83SuperSlot View Post
Man, I am in the process of wet sanding my boat right now. It looks really similar to the pics you posted on top but the gel coat is in really good shape other wise. I am hoping that after sanding, polishing, and waxing that it is able to look as good as what you were able to get... If not, I might have to go the route you did. Looks great!
Here's a couple of pics of mine since it has been redone...
Old 05-20-2010, 02:09 PM
TN X-45's Avatar
TN X-45 TN X-45 is offline
Boat: Mastercraft X-45 2008 MCX
Outstanding! Definitely partial to the blue metal flake.......
Old 05-20-2010, 02:38 PM
silverblueBP silverblueBP is offline
Boat: None
Man, that boat is beautiful!!
-Mark-
Old 05-20-2010, 02:41 PM
Thanks Guys!!
Old 05-20-2010, 03:16 PM
oxberger's Avatar
oxberger oxberger is offline
Boat: Mastercraft, Stars&Stripes, 351w, grey and blue
Awesome job! I'll be tackling mine soon. No metal flake on mine.
"The doctor said I swallow a lot of aggression... along with a lot of pizzas!"
gloss, metalflake, restoration, shine
