  #91
Old 01-15-2010, 01:44 PM
Measure once - cut twice........................ or is it the other way around.
I might be inclined to mock up a template out of a large piece of cardboard.
Old 01-15-2010, 03:11 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
I had to completly mod the teak to fit my boat.
Originally Posted by Hoosier Bob
She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
Old 01-15-2010, 11:13 PM
americanskierJim's Avatar
americanskierJim americanskierJim is offline
Boat: 1980 Mastercraft S&S Powerslot, 351 Windsor
Send a message via AIM to americanskierJim
Dash cluster gauges
I have some pic's of the dash cluster. Hour meater reads 699.3.
Old 01-15-2010, 11:24 PM
center pole removed
I also removed the center pole today. That was a job but the old metal is bad so I took it all out. I also had to beat the bottom mount off. The center pole looks great I am going to get it polished . With both mounts I am going to fab them out of aluminum.
Old 01-18-2010, 11:57 AM
The floor is out and I need to get some new plywood. What kind of wood is the best to use a marine plywood? Or just get regular plywood and epoxy it on the bottom and top?
Old 01-18-2010, 01:57 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
I've been helping out replacing the floors of an old Hydrodyne our show ski team uses. We have been purchasing marine plywood AND wraping all of it before glassing it into the hull. It adds a lot of work and materials but the finished product should definetly hold up much longer this time...
http://www.mastercraft.com/photopost...er=2572&sort=1
Need LT-1 parts?
89058397 (pump outlet side)
Old 01-18-2010, 07:49 PM
Thanks for the info JLeuck64. I will do like you said wrap them first then glass them in. I have got along weekend to get them done I am hoping.
Old 01-18-2010, 08:26 PM
What do you guys think about me using these gauges in place of the old Airguides? These are "new" and from Australia but there in KM not MPH. But I do have a set of airguides that is in MPH.
Old 01-19-2010, 10:21 PM
I took the ski pole to the machine shop today. I am going to have them cut it down 10thousands and make me some teflon bushings to fit in the steel brackets so the pole will not get rusted in again like you see in the photo's. Then off to get it all polished up.
Old 01-19-2010, 11:45 PM
That sure makes sense. That dissimilar metal thing in a wet environment just doesn't work out so well.
