What Prop for barefooting 1980 stars
Just bought a 1980 mastercraft stars and stripes with original pcm engine. 255hp?
Primary use will be barefooting. What is the best prop for barefooting? 3 or 4 blade manufacturer size pitch Thanks!! |
Contact Eric @ OJ props....he's the prop guru.
I was njskier on here. |
What is the gear ratio of the transmission, 1:1 or PowerSlot?
Eric Johnson Johnson Propeller Co., Inc OJ PROPS 800-359-9730 |
Go directly to the man that knows, Eric Johnson @ http://www.ojprops.com/contact_us or contact him by pm, EJ OJPROP, http://www.mastercraft.com/teamtalk/member.php?u=1537
Be prepared to give him any info he may need like, current prop info off the hub, the current altitude you use the boat at, baseline numbers of the speeds and RPM's for the current prop, boat model and year, engine size, transmission ratio, function (skiing, barefooting, surfing, boarding, tubing, etc.), ballast use, fuel load, gear, nominal # of passengers, etc. He will need it to determine the best prop for your application.
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
TMC#1, I'd say your about 34 minutes late on this one.
Need to wake up a little earlier ![]() |
1:1 Transmission 13 x 13 3 or 4 blade
Possibly for a minimal amount of additional top end with a 13 x 14. You will also loose a minimal amount of hole shot What you are looking for is TOP END You may max out at 45 - 46 MPH Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer www.BAYAREAWATERSPORTS.com (813) 996-BAWS (2297) |
![]() I doubt if Harold wants to wake up that early. Hey barefootjoe, I'll go footin' with you if you're close by. ![]()
I think your best bet is a 3 blade CNC. I've been happy with my Acme 541.
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition The world is full of youth—what we need is a fountain of smart! |
Welcome! Congrats of the boat, Any photos?
#10
I was reading the posts and not seeing the posters and the fact Eric had already addressed the question. Well, I'll just have to go and sit in time out. 4am, no way, I just started getting warm and was dreaming of the water lapping on the boat hull from a cool summer breeze.
| Tags |
| 1980, barefoot, barefooting, prop, propeller |
