Old 12-30-2009, 05:39 PM
Jerseydave's Avatar
TT Hero
Originally Posted by JLeuck64 View Post
Just a guess... but I think you will be disappointed with the boats performance if you go to all the trouble of making that engine combination fit. It looks like it is only a four cylinder engine in the photo.
I disagree to some extent.......diesels do take longer to "spool up" so the 0-36 mph time will suffer, but it should "hold" speed rather well (good for slalom), get 2-3 times the fuel economy of a gas V-8 and last much longer too. It would be a great engine choice in a wakeboard boat (heavy, ballast). I know diesel is the way to go for alot of reasons in europe.
Did you consider a 5.7 liter V-8 powered by propane? I know that's a good combo in europe as well.
BTW, that gelcoat is looking good! 2-week project? That's awesome! Looking forward to the pics as things progress.
Carpe Diem!
I was njskier on here.
Old 12-30-2009, 07:08 PM
Thats also a rather high RPM diesel, so perhaps the spool up time will be lessened somewhat.
On the positive side, diesels have tremendous low end torque so that may have some hole shot assistance.
Old 12-31-2009, 02:29 AM
kiteklan kiteklan is offline
Boat: Mastercraft Prostar 190 1997 ,with steyr 236 HP Diesel
About Diesel engine Steyr 236
Can't say anything before finding the exaxt prop and testing it in the sea
Transmission ratio is 2:1 which is not good that is I know but I will try to find a big prop with a high pitch.Other then that the engine is a 6 cylinder 3.2 liter gives max 440 Nm Tork at 3300 Rpm.
I atttached the engine data in Pdf.
440 NM = 324.48 Lb/Ft is what this engine produces.
RTP engine 310 HP 360 ft.lb. (488NM)
MCX engine 350 HP 380 ft.lb.(515NM)
VW TDI 225HP 335 lb (454NM)
1 foot-pound is closely equivalent to:1.3558179483314 newton meters
I think in respect to fuel economy and performance ,overall we will get a 4/5.
Thanks for the comments.
Old 12-31-2009, 02:47 AM
Why Diesel Engine
Carpe Diem!
Nj,It took about 2 months to find this engine,those engines are not still show up in the 2nd hand market,this engine was at 600hr and year 2002 that is why we chose it.
For the progress check the pictures .
Name Stickers were for registration,we will work on something look nice with decals .
Old 12-31-2009, 02:59 AM
http://www.indmar.com/ProductLine/In...256/index.html
Inmar is using the same engine with 256HP,mine is 236.
Old 12-31-2009, 03:29 AM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
I am pulling for ya! Hope you can make that combination work with some trial and error in the prop selection.
RTP engine 310 HP 360 ft/lb (I think this should be Lb/ft but MC site uses as it)
MCX engine 350 HP 380 ft/lb
VW TDI 225HP 335 ft/lb
Need LT-1 parts?
89058397 (pump outlet side)
Old 12-31-2009, 04:03 AM
JLeuck,I am really not sure about the end result,but made comparison with the figures above.I will post all the results here.
Old 12-31-2009, 08:50 AM
End of year 2009
Check out the pictures.
Old 12-31-2009, 08:57 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
Wow, looks great.
Old 12-31-2009, 09:13 AM
markismm's Avatar
markismm markismm is offline
Boat: 1984 Stars and Stripes
Very interesting using a turbo diesel in that boat. Do you think that the turbo is going to stay cool enough not to melt the engine box? I'll bet you can swing a rather large prop with a high pitch with that torqy motor. Do you know what the motor came out of?
diesel engine, renovation, repair, steyr
