Awesome help! thanks a lot1
#12
some pictures
thanks for all the help from the core. Here are some pictures.
#13
You have the standard 350 TBI engine. Very reliable and plenty of power.
Definitely fix the gelcoat damage ASAP.
1996 Prostar 190, 350 TBI and Powerslot |
#14
thanks a lot for taking the time to respond.
#15
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#16
Sorry I didn't mention, but you may have gathered anyway, it is a GM 350 Throttle Body Injected motor.
In addition to changing the engine oil and transmission fluid, I would replace the raw water pump impeller ($30) and fuel filter, unless you know they are new. Other basic maintenance items like cap and rotor, plugs, wires, etc. are up to you, but they can prevent you from being stranded and ruining a nice day on the lake.
#17
thanks
appreciate the info man, it really helps, I've been on the salt water for most of my life and this is the first ski boat, i'm excited and nervous because I've had a lot of luck with outboards mostly being able to work on them myself. Being that this is the first inboard, seems things are more expensive and just want to do the right things at the begining so that I can minimize any probs in the future, since I dont know how well kept the boat was by the previous owners.
#18
#19
By the general apeparance of the motor, the PO wasn't much into upkeep. Oil, 15W40 diesel grade oil reccomended, but any automotive engine oil will work fine...same engine as a Chevy pickup. AC PF454 or Napa 1069 oil filter. Suck out the trans fluid and change it. Get a $10 drill operated pump and some hose/fittings from teh hardware store to make a pump for teh engine oil and trans oil.
Impeller, fuel filter, clean the air filter, check all teh hose clamps, grease the steering cable and rudder (under panel behind the motor). Tune up if needed. If you're used to outboards, IMO, these are much easier to work on. Most general parts are available at teh auto parts store too. If it runs good, don't bother draining the gas, these engines are not that finicky. If you need to drain it, disconnect the line coming out of the fuel pump and stick a hose on it. Run 12V with some jumper wires from teh battery to the fp terminals an pump away. Drain the extra fuel out of my 190 every year like this (careful of sparks!). Hammer out the prop and if it doesnt vibrate, you're ok, but not great. A new prop will do wonders over the stock OJ cupped prop. Many threads on the best prop. Fix the gelcoat. At least paint or gel over that damage before putting it in the water anymore so the 'glass doesn't absorb anymore water. If it's been wet recently, I'd let it set and dry with nothing on it for a while.
#20
youre the man!
Thanks for the details thats what I needed/wanted. People like you make it worthwhile to join this site. At the risk of being heckelled again, could someone tell me where to put the water hose into the engine so that I can start it without the boat being in the water? thanks.
| Tags |
| fuel, gel coat, indmar, oil, prop |
