  #101
Old 08-17-2009, 12:47 AM
MariStar-Man's Avatar
MariStar-Man MariStar-Man is offline
Boat: 1999 Maristar 210 VRS
Question My poor stock Bimini Top...Pic
Since the previous owner installed and X SERIES Tower, My stock bimini top wont open. Is there a way to redisign, without calling Johnson over to stick there hand into my shallow pockets...
My girl, always in front of the camera...hahah
Old 08-17-2009, 06:34 AM
bturner2 bturner2 is offline
If you were a pint low a I would think about going through your brakes. If you have drums one or both of the cylinders could be leaking. If you have disc then the pads are probably worn. Either way I'd want to know where that fluid went.
Depending on how old the trailer is I'd probably recommend flushing the old brake fluid out and bleeding the brakes at the same time.
Trailers are the most over looked area of boating until your stuck on the side of the road.
Old 08-17-2009, 06:43 AM
Dave2302 Dave2302 is offline
Boat: 1994 Prostar 190 5.7 litre GM on LPG
Ridiculous !!!!
The block drain (red hose), is not large enough for good flow nor is it the hottest water source. The hottest source is on the intake manifold just where the water passage comes out of the head, and there should be a bung, as its where the car heaters are plumbed.
The return (blue hose), should go into the circulating pump (not the raw water pump), for the best pumping and again there should be a blanking plug as the car heaters are returned here.
These are always the locations that we plumb the LPG vapourisers over here which gives a good supply of hot water. If your boat does a lot of running below 1500 rpm you can also fit a smaller pulley and shorter belt to the circulating pump to speed up circulation.
The bungs can sometimes be difficult to remove especially on old engines or those run in salt water, but usually a little heat will get them out, then a couple of 5/8" hose barbs with bsp threads can be screwed in and Robert is your mothers brother !!
HTH Dave.
It's Nice To Be Important But More Important To Be Nice. Keep On 'Footin'
Old 08-17-2009, 07:59 AM
jimmer2880 jimmer2880 is offline
Boat: 95 PS 190 EFI
Send a message via AIM to jimmer2880
That's where Heatercraft says to plumb. For mine, I plumbed at the intake (It's a T with my Heater). For Cold, I followed Heatercraft's example and T'd into my raw water intake as shown. in the OP's pic.
I have excellent flow and couldn't imagine needing more. The hot is very hot. So much so, that I only have the Hot knob about 1/2 and Cold Full.
If one day you're asked:
" How did you spend your time here on Earth?"
Will you say:
"I kept a crabgrass free lawn"
It's time to SKI.
Old 08-17-2009, 08:02 AM
Boat: 95 PS 190 EFI
Your bimini tubes should separate in the middle. You should then, be able to cut them down to fit between your tower uprights. Then, you would need to take the fabric to someone to have it cut down as well.
I don't know of anyone who has actually done this, but it should work.
Will you say:
It's time to SKI.
Old 08-17-2009, 08:15 AM
Maristar210's Avatar
Maristar210 Maristar210 is online now
Boat: paddle
There. Now there's another person to add to the list.
Coz you see a pattern with growing number ofthose who don't care for you in here?
Old 08-17-2009, 08:43 AM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
Dude! W T F? I don't give a damn what you think or do! hurry up and ad me to your list.
Old 08-17-2009, 08:46 AM
kev88 kev88 is offline
Boat: 2017 X-20
You have to admit - all this '"friendly banter" keeps us coming back.
2017 X-20
Old 08-17-2009, 08:53 AM
Chicago190's Avatar
You might be able to crank the winch hard enough to slide the boat forward, but I doubt it with the hull and bunks dry.
Old 08-17-2009, 08:56 AM
dpolen's Avatar
dpolen dpolen is online now
Boat: Med Blue 2012 X2, Illmor 5.7
Send a message via MSN to dpolen
Is there any way you could attach it to the outside of the tower, maybe on the front legs or the side support? I know I have a different tower, but this installation has worked really well for me. I got the tower mounts for the bimini for about $20 at diywake.com
Another thought after looking at your picture some more, I bet if you move that bimini support base forward about 18", you could simply let the bimini rest in front of the tower, still keeping everything kosher for boarding while the tower is up. That's probably your cheapest option. Might have to add/reposition the hooks for the nylon straps too. Good luck!
Mediterranean Blue 2012 X2
2013 Ford Expedition EL Limited
He who dies with the most toys wins...I'm losing right now!!!
