Old 07-31-2009, 09:52 PM
GunmetalFlake
Guest
Posts: n/a
Question How to tighten the 2007 tower (X-45)
I have a 2007 X-45. Recently, my tower started to move around a lot (not just your usual shake), and it turns that the rear starboard mount (behind the driver) was crazy loose.
That mount is held down by two hex bolts that appear to be held down by a nut under the gunwale. I looked under the gunwale where the mount goes in, and there's a very small opening to reach in and access the bottom of the bolts. The problem is that the opening is right under the rear (aft) bolt, and it literally seems impossible that a hand with any conventional tool (e.g. a spanner wrench) can fit in there to grab the fore bolt.
Does anyone have tips on tightening this part of the tower?
Thanks.
Old 07-31-2009, 10:02 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
Thanks.
Deep Well Socket on a universal and long extension?
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 07-31-2009, 11:07 PM
SOCALX45's Avatar
SOCALX45 SOCALX45 is offline
Boat: MC X45 07
Once you tighten it up if it still shakes to much for you try getting the braces put...thats what i did to my 07 x45 and it still shakes but not as much as it use to!
2007, loose, tighten, tower, x-45
