You'd need to list all of the accessories you want to run in order to tell. The power formula is P=IE, (P is Power, I is Current and E is Volts). Nothing is 100% efficient, so unless the amps state their draw vs output, assume they're about 60%. 300W/ch is 600W total and if it's 60% efficient, that's about a 70A draw if the voltage is 14.4, more if the voltage drops (which it does at low RPM and when the alternator and battery are under heavy load.
#12
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#14
Just after I posted last time, I called the shop to find out what the next size up can put out and he said about 165A. This case isn't exactly the same size but the brackets still fit. The span at the pivot is the same and it's a little deeper, larger diameter. This shop only rebuilds starters and alternators.
| Tags |
| alternator, amplifier, battery, stereo, wetsounds |
