Old 05-31-2009, 05:54 PM
alex alex is offline
Boat: X-star 2004
What is this broken connector?
What does this do? Check out the circled parts in the pic, i can figure out that much that they're supposed to be connected, but what does it do? where do i get a new part for the cables to connect to? it was this way when i bought the boat last year and everything is working, i think
Old 05-31-2009, 06:19 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Neutral switch?
Transmission temp sensor?
What boat,year and transmission maker?
Keep skiing!!!
Old 05-31-2009, 08:25 PM
CantRepeat's Avatar
Boat: Boat
That looks like temp, the one with the cover still on it looks like neutral switch.
Tim
Gone, surfing.
Old 05-31-2009, 09:53 PM
Gamble's Avatar
Gamble Gamble is offline
Boat: Mastercraft Prostar 209 310 Predator
what Maristar said..........they yellow/brown wire is the nss.
Old 06-01-2009, 10:04 AM
snork snork is offline
Boat: 07 xstar
Trans temp sensor. My wire broke and was an easy fix to replace the sensor. don't over tighten. But then I could be wrong
Old 06-01-2009, 11:02 AM
Boat: X-star 2004
ok, thanx a lot. It's a 2004 X-star but temp seems to be right. Looks like it's an easy fix, so i'll just get a new one then.
Old 06-01-2009, 11:33 AM
CantRepeat's Avatar
Boat: Boat
It doesn't measure the temp of the motor. It measures the temp of the tranny and it doesn't have a gauge output. If you over heat the tranny it should just make a semi load buzzing noise to warn you.
Tim
Gone, surfing.
Old 06-02-2009, 12:19 PM
Boat: X-star 2004
ok, i found a buzzer underneath the dash that was disconnected, so i guess thats the one? It's hard to figure everything out when you buy used stuff.
connector, drivetrain, v-drive
