Old 10-22-2008, 07:45 PM
Grover777's Avatar
Grover777 Grover777 is offline
Boat: 2001 PS 209
Replacing Blower Ducting
Hi:
While I was changing the oil filter on my 2001 PS209, I tore my blower duct (it runs right under it). The tear kept getting worse every time I touched it. I was going to use Tyvek tape to repair, but I have about a 6 inch area that is torn up and it is next to impossible to access the torn area.
How hard is it to run new blower ducting? It looks like I will need to remove a floor panel behind the motor box.
Any suggestions??
Thanks!!
2001 Prostar 209
1959 Glaspar Trident
Old 10-22-2008, 09:07 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Its not a bad job, but you might have to remove the panel behinf the motor box.
Some models have a hard pvc like tube that runs most of the way back that the flexible tube connects to. I am not sure about yours.
OH-IO!
Old 10-22-2008, 09:12 PM
TMCNo1 TMCNo1 is offline
MC Hero
Boat: Gone
Simple, you put it back in just like you took the old out and the hose can be found at most any boat dealer and here, http://www.skidim.com/prodinfo.asp?number=MPI402-30000
Charter Member Number 1
Quote: 2RLAKE,
Old 10-22-2008, 09:14 PM
Grover777's Avatar
Boat: 2001 PS 209
I have not taken the ducting out yet.
How does the floor panel come out?
Thanks!!
2001 Prostar 209
Old 10-22-2008, 09:16 PM
Footin's Avatar
If it is like my 205, you take off the motor box then the six or so screws the hold down the panel. Lift it straight up and out.
OH-IO!
Old 10-22-2008, 09:42 PM
Chicago190's Avatar
If you look at the floor behind your motor box you will see that it is a section. Two ways to take it out. 1. Unscrew the hinges on the motor box and then there should be 4-6 screws which attach the floor to the boat. Lift out floor section. 2. Leave motor box attached and just undo the floor screw, and take out the floor and motor box as one section (two people may be needed for this approach.
On mine, I also had to remove the rear seat and also the vertical piece in front of the gas tank to get back far enough to remove the blower hose.
You could also do what I did for a season, which was to cut out the damaged section of blower hose and duct tape in a piece of expandable dryer vent hose to seal up the two sections.
Old 10-22-2008, 09:49 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
To save a few bucks, head to a hardware or home supply store that carries RV stuff. In that department, you'll find the same size flex hose used in the RV world for waste water hook-ups. I bought one box (not sure how many feet were in it) for less than $10 and have enough left over in case I ever need another replacement.
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
Grover777's Avatar
Boat: 2001 PS 209
Are the screws holding the floor to the boat under the carpet?
2001 Prostar 209
Old 10-23-2008, 02:18 AM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
Me too. I think it holds up better than the original
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 10-23-2008, 12:46 PM
Chicago190's Avatar
Not on my boat, and I assume unless you have snap out carpet they shouldn't be. On my 190 there are two underneath the motor box and two more at the very rear underneath the rear seat. Maybe someone with a 209 can clarify the procedure.
