Old 08-17-2008, 11:08 PM
Ryan's Avatar
Ryan Ryan is online now
Boat: 1993 Prostar 190 285hp HO
Originally Posted by Footin View Post
As I told you before, good move taking it in.
We had a great time on Buckeye Lake Saturday, even called the pizza shop on the lake an placed a to go order and picked it up on the boat. Went to the sand bar and had a family picnic.
See, now we could meet out there before the lake freezes over.
Choose The Right
5mph>Wakeless Speed>32mph
Old 08-18-2008, 12:16 PM
btriantos's Avatar
btriantos btriantos is offline
Boat: 2007 X30, MCX
Hve you checked the prop??
Old 08-19-2008, 02:28 PM
Ryan's Avatar
Yes. It would have to be missing a blade to do what it does in the water. But, the trick is, the condition can be replicated in the driveway after I wet the drive shaft and cutlass bearing. It can happen as soon as I put it in gear, and if not then it will do it when I carefully apply some pressure to the drive shaft coupler with my boot.
Choose The Right
Old 08-19-2008, 02:40 PM
Sodar's Avatar
Sodar Sodar is online now
Boat: '07 ProStar 197 w/ MCX
Has the dealer called you for an update, yet?
Old 08-19-2008, 03:50 PM
Ryan's Avatar
Nope, I know it's OH and all but there is still a little wait list. I had to drop it off Sat for a Tues eval. I'll let you know.
Here's to keeping it under 12 hours to remedy eh?
Choose The Right
Old 08-19-2008, 03:53 PM
Sodar's Avatar
What a load of BS! I am sure the SoCal dealerships could have had you in on Saturday..... It would have been Saturday, Sept. 20th, but it would have been Saturday!
Old 08-19-2008, 07:22 PM
Hunterb Hunterb is offline
Boat: 1990 Prostar 190 351
I still think you might want to check the damper plate. I suspect the sound you are hearing when you engage the transmission and the backfiring are separate issues.
Hopefully it's not too expensive or too long before you get the boat back.
Bruce
1990 Prostar 190, 351 Indmar SO, bought as an empty shell and rebuilt over the winter (04/05). Sold in May 2009
New boat - 1993 Prostar 205. Bought in better shape than the 190 was but still needed some work.
Old 08-19-2008, 07:31 PM
Have you checked to see if the strut wobbles? If it doesn't, with the keys in your pocket, sit on the ground or a blanket, facing the prop. Grab the prop (wear gloves to avoid cutting your hands) and rotate the prop quickly. It should move smoothly with no additional sounds.
Old 08-19-2008, 07:49 PM
Footin's Avatar
Footin Footin is offline
Boat: 1994 Prostar 205, previously owned 1991 Barefoot 200, 1987 Prostar 190
Ryan, If you get it back in the next week a few families are getting together at Alum Creek.
OH-IO!
Old 08-19-2008, 09:02 PM
Ryan's Avatar
I tested this at the end of last season. At the time I thought believed the cause had to do with the shaft, bearing, alignment, strut, loose prop etc... but I never could rule out the damper plate as a culprit.
I do regret not replacing the shaft packing while I had the floor up and all.
I still wonder if the timing is off and that putting the transmission in gear is just enough resistance on the crank shaft to miss a spark here and there. I don't have a timing light and have never used one. But, lack of experience hasn't held me back before. I figure I'm at least as smart as the guys in the shop, if they learned how so can I...as long as I have time. Plus, my wife started saying she wants to hurry up and get on the water twice a week!
Choose The Right
engine trouble, gt40, hiccups, ryan, transmission
