Is there any possibility that this is a damper plate issue?
Bruce
1990 Prostar 190, 351 Indmar SO, bought as an empty shell and rebuilt over the winter (04/05). Sold in May 2009 New boat - 1993 Prostar 205. Bought in better shape than the 190 was but still needed some work. |
#12
Why would you think it's that?
Sure, it's possible but with old wires that are tightly tied to each other, it's less likely. Check the easy stuff before you dig into that kind of thing. Diagnostics is testing, not getting suggestions and asking more questions after not doing the testing. It would be nice to have a little light that goes on and corresponds to the exact causes but we need to do the work in order to find out why things have failed. |
#13
I thought that too, but the tranny shop seriously doubts it. I'm going to check compression and put on new spark plug wires this weekend. I'll return & report.
Choose The Right 5mph>Wakeless Speed>32mph |
#14
So much for getting that done last weekend.
Compression comes in between 135 -140 psi with most right smack in the middle at about 138. I need to verify my methodology, I had all spark plugs out and for each test cranked 5 revolutions. I also checked it with 7 revolutions and all come in just a hair over 150 psi. Let me know if I am off base and should be taking the first or second reading. New Bosch spark plug wires have made no difference.
Choose The Right 5mph>Wakeless Speed>32mph Last edited by Ryan; 08-12-2008 at 09:04 PM. |
#15
Ummm,
Ryan have you checked your drive shaft alignment lately??? The only reason I ask is because earlier this season I was experiencing a vibration much like yours. Come to find out my alignment was OK, but the bolts/nuts had loosened just a tad.
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#16
Any new news Ryan?
OH-IO! |
#17
Have you looked into the mufflers, from the rear? I would also look from the engine side, too.
Just a thought. |
#18
if you havent changed the cap and rotor yet i would recommend that you do !! i had a similar problem few years back with a hairline crack in the cap being the route cause , but it only broke down when the engine heats up . do you know if the electronic ignition module is the original as this can also start to break down under heat as it starts to go south ??
just a few thoughts . rob.
nil satis nisi optimum |
#19
I checked the alignement and the cutlas bearing at the end of the season last year and all is well.
Jim, I've got to know...what would I be looking for inside under the exhaust flap? A mouse nest perhaps? Thanks for all the ideas guys. Current update - I'm out of time. I dropped it off at the local Bu dealer the only shop in town with a mechanic that knows Indmars well.. Their mechanic has been working there for 15+ years back when the dealership sold MCs. Being the middle of August I can't go two summers with a boat not in full operation. We're missing good valuable time on the water tinkering and testing in between a busy schedule. I'll keep you posted on the diagnosis.
#20
As I told you before, good move taking it in.
We had a great time on Buckeye Lake Saturday, even called the pizza shop on the lake an placed a to go order and picked it up on the boat. Went to the sand bar and had a family picnic.
OH-IO! |
| Tags |
| engine trouble, gt40, hiccups, ryan, transmission |
