Old 06-01-2008, 06:16 PM
justinglow's Avatar
justinglow justinglow is offline
Boat: 1995 Prostar 205
How do I take this cover off?
I need to get to my gas tank to check my sending unit. Any idea how this back cover comes off? I already took out the two screws in the corners. That's all I found so far. It's a 98 Sportstar. Thanks!!
1995 Mastercraft Prostar 205
Former 1986 Mastercraft Skier
Old 06-01-2008, 06:17 PM
justinglow's Avatar
Found one screw on each side.....
Old 06-01-2008, 08:55 PM
justinglow's Avatar
bump......
Old 06-01-2008, 09:02 PM
Gonzo's Avatar
Gonzo Gonzo is offline
Boat: 1998 MariStar 225VRS
On mine you just pull out from the bottom and the brackets that hold it up top slide down with the cover. In fact after I got it out I found straps that should have been on the outside to help with it.
-Cory 2.0ld
98 Maristar 225VRS - "Frankenstar"
91 PS190 -Sold
RIP No1
T Scott T Scott is offline
Boat: It's always changing! X-Star-Prostar190/205-Maristar
I am almost certain that there are only the two screws holding that cover on. Unfortunatly, they are the screws you already took out! Have you tried to get something underneath it or behind it to pull it out? I would try and pull it from the bottom first.
Old 06-01-2008, 09:10 PM
justinglow's Avatar
It's all attached right? So when it comes out even the deck pad should come with it?
Old 06-01-2008, 09:13 PM
No the sun deck pad is not part of that assembly. However, I believe the striped cushion (backrest) is mounted to that rear cover. Try and pry it out or get something behind it down by the floor and see if you can't coax it out.
Old 06-03-2008, 04:31 PM
tcubrian tcubrian is offline
Boat: 1998 Sportstar
Pull the top pad off first. Lift the pad at the back part of the boat. It uses push in fasteners for the back part and then you will have to slide the pad aft. That will actually give you access to the sending unit.
If you still need remove the backrest pad, it just pulls straight up once the top pad is removed.
If this doesn't make sense, let me know and I will take some pictures tonight.
Brian
Old 06-03-2008, 04:40 PM
beef beef is offline
Boat: MC Prostar 205, 1998
My 98 205 pulled straight up in the front and the slid forward, towards the bow. The snap in connectors did break off, like the ones used to hold in door panels on a car. I used heavy duty velcro to re-attach & that seems to work fine.
Old 06-03-2008, 05:28 PM
justinglow's Avatar
Brian
If you could take some pictures that would be great.
