Ok that is the motor. So I am missing the carb spacer plate! Anyone know if the performer manifold with that plate is going to create a clearance problem?
Probably will. Check the base of the carb to see if you have a vacuum port that is capped on it. If so you can use that. If not you can get a low profile flame arrestor from DIM. You can also probably pull one of the plugs out of the manifold and add a fitting so you have a vacuum port straight from the manifold. Doesn't really matter where exactly you are getting the vacuum from.
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
#13
My 351 Indmar engine does not have a PCV valve going to the spark arrestor. Should I be buying a new arrestor and valve cover cap with a PCV valve in???
#14
Here is mine, hope it helps. Looks like I've got the vent cap you mentioned but I've not had a problem with oil mist. Post your setup when complete.
Current - 2008 X2 2nd - 1999 PS 205 Blue/White, LTR 1st - 1991 PS 190 Red, 351w & Powerslot |
#15
My 351 Indmar is exactly like hester's and I don't have a problem with oil mist either.
#16
There is nothing wrong with your setup. Only thing is I would think twice about putting that vapor under your engine cover. The proper setup for your boat would have a tube coming from the oil cap up to the flame arrestor. There is not supposed to be a PCV valve in this line. Just an open line that burns vapor. The reason I get the oil mist is because my filter is opposite of yours. As the boat is coming out of the hole, all the oil in the rockers goes to the back of the cover and mist's heavily. Once I get home I will post some ics. I'm in Austin are right now. Just had to replace exh manifolds, risers, circ pump, distributor, and impellor. Cha ching!!! But runs like a raped ape right now!! Got some carb tweaking to do. Secondaries need to be adjusted a little, and I'm going to 86 my mufflers for straight pipes! Remember, loud pipes save lives!!
I have the same set-up as hestor. I don't think it should have a misting problem as the cap on the left side of the motor should have air going IN only and the other side has the air going OUT and routed into the intake via the carb base plate. I think the only reason that some boats have the hose going up to the spark arrestor is to get some filtration of the air going into the crankcase.
Bruce
1990 Prostar 190, 351 Indmar SO, bought as an empty shell and rebuilt over the winter (04/05). Sold in May 2009 New boat - 1993 Prostar 205. Bought in better shape than the 190 was but still needed some work. |
#18
The cap is designed with a filter element inside of it. Engines that run the hose up to the air filter have the filter up there. You should not have mist coming out of the filler cap or into the air cleaner if the hose runs up there. As was mentioned, air should be entering the crankcase at that point. The mist would indicate a clogged PCV valve or excessive blow-by (likely worn rings).
1996 FlightCraft Barefooter—Merc 200 EFI 1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition (SOLD!) The world is full of youth—what we need is a fountain of smart! |
#19
I'm late, but I'm still posting old engine pics!
![]() With the stock flame arrestor and a spacer under the carb, you may run into clearance problems. I did on my 93, but the 93 engine box was smaller. Unfortunately, these are harder to find than they used to be. ![]() But if you can get a low profile flame arrestor, do it. Mine wasn't plumbed into anything from the flame arrestor, but the spacer was plumbed to the starboard side valve cover. Another option for gaining space is to build a collar for your engine box to raise it off the floor. There was a guy on CCfan that did that and it looked pretty slick. Can't remember who it was, but TRBenj could tell you. Also, check your throttle cable to make sure it's running close to level. Mine required a bracket to keep it from binding up after everything got raised up 1.5".
Previous: 1993 Prostar 205 Red 1998 Ski Nautique, PCM GT40, 310 hp, , Acme 4 blade, Perfect Pass SG/Zbox. FAQ Be kind. Have fun. |
#20
Well I took some pics but cant upload them because of size. Any ideas??
Thread Tools | |
Display Modes | |
