  #231
Old 10-31-2017, 10:24 PM
osmonet's Avatar
osmonet osmonet is offline
Boat: 2008 X2, MCX
Originally Posted by Jpero View Post
Iím new here. Forgive me if Iím jumping in the wrong thread! I have an 01 Sammy Duvall and need replacement side hull decals. I realize it is unlikely that any OEM are available. Can anybody direct me to a known source for these? I have found regular MC decals out there for various years, but no Sammy.. Thanks.
Will these work?
https://greatlakesskipper.com/master...t-decal-single
Old 10-31-2017, 10:44 PM
looking for flat or raised decals?
Old 11-02-2017, 06:48 PM
Jpero Jpero is offline
Boat: 2001 Sammy Duvall
I was thinking flat so they would be less likely to wear if they rub on the boat guides of my lift. I took a look at the one from Great Lakes Skipper (thanks for posting that). It looks just like mine, but I'm guessing from a few model years newer. I'm basing this on the fact that it is the raised foam type. Mine were definitely regular flat decals. Are the raised foam ones fairly resilient?
Old 11-04-2017, 08:11 PM
herscman herscman is offline
Boat: MasterCraft 1978 351 Windsor
Decals
Hi,
You might give this guy a try, he helped me with a special size for my trailer.
http://www.ebay.com/itm/MASTERCRAFT-...-/222148551130
Hope this helps,
herscman
Old 11-05-2017, 12:21 PM
as all vinyl - it will last longer if not left in the sun or abraded. -- the key is the type of vinyl used. most ebay guys use and inexpensive colored vinyl that is called calendared easy to separate waste from wanted graphics but not the best. laminated cast vinyl harder remove waste are much higher quality and have adhesive micro beads and air egress channels resulting in a better installation - hence lasting longer graphic.
Old 11-06-2017, 08:57 AM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
maybe a little color filtering...still needs some work... but as a concept...
This is the one on my 1998 Pro Star 190, Mike. What do you get for two of them in Teal?
Old 12-06-2017, 09:08 AM
pbrundage pbrundage is offline
Boat: Mastercraft, X35, 2011, 6.0
ISO X35 Decal?
Hello all, still in search for the Glacier White X35 "Switch" decal. Any recommendations? MC part #7501468 however dealers cant get it, can't find it at any of the normal suppliers either. Do you know anyone that could make it? Below is a link to a black version of the decal.
Thanks for the help!
https://greatlakesskipper.com/master...01561-set-of-2
Old 12-06-2017, 11:08 AM
call MC to get part number - then contact u-p.com - they will make it for you.
Old 12-27-2017, 08:07 PM
Southcoastbarefooter Southcoastbarefooter is offline
Boat: 1993 Barefoot200
Mike,
I have a '93 Barefoot 200 and am looking for all side decals....25th anniv., Barefoot 200, and Mastercraft white w grey shadow.
Would you let me know?
