Old 11-30-2017, 12:32 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Yes just use the flush connection to run the engine. It's designed to be run like that.
You know not to just turn on the water without starting the boat immediately, right?
I disconnect the raw water intake hose to the engine, stuff the garden hose in it and water the engine that way. Same as flush connection
'06 X2 MCX
Old 11-30-2017, 03:03 AM
lda6339 lda6339 is offline
Boat: 2016 Mastercraft X-30 6.0L
I watched the tech from TXMC do the first oil change on our boat while it was on the lift and he didn't heat it up, just used a fluid extractor.
Old 11-30-2017, 06:16 AM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
This is the oil pump i bought a couple years ago ... was a thread on here as well
Old 11-30-2017, 06:22 AM
2RLAKE's Avatar
Found one of the threads
https://www.mastercraft.com/teamtalk...ight=extractor
Old 12-03-2017, 11:06 PM
paintpollz's Avatar
paintpollz paintpollz is offline
Boat: 2002 Prostar 197
i bought it too and omg where has it been all my lifeeeee
Kevin
Old 12-05-2017, 12:00 AM
Thrall's Avatar
Boat: '06 X2 MCX
I know....I've been draining oil, slowly, using drill motor pumps, even turkey basterd, lol, to change oil, trans, etc for years. Broke down and bought a vacuum extractor last year. Sooo much easier.
'06 X2 MCX
Old 12-05-2017, 12:06 AM
Thrall's Avatar
Boat: '06 X2 MCX
Originally Posted by MC25 View Post
Typically the first oil change is free, unless youíre crazy far from the dealer and it doesnít make sense to drive.
Unless I was less than 30 min from the dealer and they were doing oil changes for $59.99 I'd do it at home.
Even at a half hour away, that's 2 hours drive time to drop off and pick up. Call it 3 hours.
In 4 hours I can change oil, trans fluid and Winterize the boat including ballast.
2 gallons of 15-40, oil filter and 3 gal of windshield washer fluid, 1 for each ballast tank. $50
'06 X2 MCX
