  #5041
Old 08-21-2014, 12:42 AM
sr56 sr56 is offline
Boat: 1993 MC 205
Mikeg- looks great. Were you able to use the same roller shaft as before?
Old 08-21-2014, 01:05 AM
john jones john jones is offline
Boat: 2002 Xstar
Mike where did you get those outer rollers and longer pin?
I better do the same
Old 08-21-2014, 09:16 AM
carlsonwa's Avatar
Boat: 2006 Prostar 197 TT
Replaced the starter on my 99' I was starting to hear some grinding coming from the starter during crank. Pulled out the starter found that the main shaft was loose due to the bearing (s) being shot. Found a place right here in St. Paul that rebuilds starters, Walters Restoration. Purchased a rebuilt starter for $140 in the same day as dropping mine off. Good as new!
Old starter video of loose shaft
https://www.youtube.com/watch?v=190goZNKQaI
pics of the new starter
Old 08-21-2014, 10:04 AM
Thanks.. the MCOCD got the best of me...lol so I added them - no more hull gouge if I ever goof at the ramp... I don't want to show up in the boat ramp blooper thread...
I got the rollers from http://www.easternmarine.com/catalog...sult/?q=stoltz
You need the longer roller shaft http://www.easternmarine.com/5-8-x-1...er-shaft-86041 - and they you need to take about 1.25 inches off. I cut it with a jig saw with a steel cut off blade
and pal nuts of course. http://www.easternmarine.com/5-8-rol...pal-nut-10801c
mike
Old 08-21-2014, 10:13 AM
monsterwake's Avatar
monsterwake monsterwake is offline
Boat: 2017 NXT22
Added the outer rollers to my newly added keel roller just because.. next up is a new winch.. the little piece that covered the click lock fell off.. still works but now I will be thinking about it..prolly wont go fulton - but maybe...
Old 08-21-2014, 09:15 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Installed new steering wheel tonight.
Old:
Mike B
Old 08-21-2014, 09:17 PM
orbeamlb's Avatar
And the New.
Went with a symmetrical style since my boat has hydraulic steering which doesn't keep the wheel centered like cable steering.
Mike B
Old 08-21-2014, 09:35 PM
orbeamlb's Avatar
Mike G,
Did you add the keel roller to your trailer? How high does it sit above the cross-member? My trailer has a rubber pad on that cross-member.
Mike B
Mike B
Old 08-21-2014, 11:43 PM
Originally Posted by orbeamlb View Post
Mike G,
Mike B
I didn't add the roller - a quick measure indicate the center of the roller is 3" above the top of the cross member.
Old 08-21-2014, 11:44 PM
And the New.
sweet steering wheel.. - which steering system did you install?
