Old 08-21-2014, 03:41 PM
tommurtha tommurtha is offline
Boat: Prostar 197 2003
where does the perfect pass plug & play harness hide
I have a 2003 prostar 197, trying to install a older perfect pass module and step motor etc.that came with the boat uninstalled. I had no harnesses. Perfect pass has been helpful but so far no joy. They made me a harness as I was missing it. They said it is under the dash, it isn't as far as I can see, They mentioned a panel that unscrews (maybe) that I don't recall seeing. (The boat is 90 minutes away). The mat area by my feet unscrews, there? It is a 6 hole connector that I can't seem to find. Perfect Pass said every Mastercraft from 2002 has the plug & play harness. Please help me find it. I'm no good at wiring from scratch
Old 08-21-2014, 04:04 PM
franciscolalas franciscolalas is offline
Boat: Prostar 209 2004
Hope it helps!
Look for the connector behind the foot panel.
Old 08-21-2014, 04:29 PM
Jayhawk's Avatar
Jayhawk Jayhawk is offline
Boat: 2001 X-Star
http://www.mastercraft.com/teamtalk/...ad.php?t=58473
Old 08-21-2014, 05:29 PM
nice link that may come in handy if I can ever find the connector in the boat
Old 08-24-2014, 09:59 AM
found my connector. Unfortunately it looks like mastercraft took a crimping tool to it. It is so distorted that it won't come close to plugging in. So what should have been a plug & play is now cut and install a new plug. Nothing ever seems to go easy
Old 08-24-2014, 10:28 AM
Boat: No Boat
Don't cut the wires, get the correct tool and de-pin the plug. Then just replace the plug.
Old 08-24-2014, 10:36 AM
I could not figure out how to de-pin the plug Any idea how and where to get the tool. I was planning on heading to Radio shack to see what they might have. The mating connector from perfect pass does not look like is comes apart. The wire terminals snap in I can push the wire & terminal out and pull s back in with a snapping sound.
Old 08-24-2014, 10:42 AM
Boat: No Boat
I'd have to go look at my plug, but I bet either a delphi de-pinning tool or weather-pak tool would work.
https://www.google.com/search?q=delp...=1920&bih=1080
I have both and would think the weather-pak tool would work if the pins are the round type.
Old 08-24-2014, 11:12 AM
On the connector perfect pass sent, It sure looks like the wires are inserted then crimped to the terminals then pulled back into the connector, snapping in. I assumed the boat connector is the same.
Old 08-24-2014, 11:20 AM
Boat: No Boat
I'm not sure, I'd have to go look at mine. It's been a while.
