Old 08-18-2014, 05:04 PM
triton triton is offline
Boat: 2005 Mastercraft Prostar 209
Vibration under load
I have a slight vibration coming out of the hole when pulling my 70lb son out on his wakeboard. The boat has no vibration after that all the way to wot. I also notice it when powerloading the boat on the trailer. On the trailer, my dash and steering wheel shake. Any ideas would be appreciated.
Thanks
Old 08-18-2014, 05:16 PM
markmcfarland's Avatar
I'd say check the prop first. If you have a spare try it.
Old 08-18-2014, 07:06 PM
check the cutlass bearing could be worn from bad alignment.
Old 08-19-2014, 09:36 PM
waveslayer waveslayer is offline
Boat: X9, 2003
I would check the prop and the the bearing
Old 05-28-2017, 10:09 AM
CheeseSteak1's Avatar
CheeseSteak1 CheeseSteak1 is offline
Boat: 2009 X30 MCX / 2003 X2 MCX
How do you check the cutlass bearing? I assume remove the prop and do a visual? I'm having this exact same symptom which just started yesterday. Going out with spare prop today to eliminate that as a possibility.
Old 05-28-2017, 10:35 AM
oldsmobiledriver oldsmobiledriver is offline
Boat: 2012 MB Sports F21 Tomcat
Grab the prop and try to shake the shaft side to side, should have very little to no movement.
Old 05-28-2017, 10:43 AM
snork snork is offline
Boat: 07 xstar
if your steering wheel shakes you likely need to grease the rudder port
vibration under load you 'll need to tune your prop
Old 05-28-2017, 12:22 PM
All helpful information. Thank you
Old 05-29-2017, 11:53 AM
redearevets redearevets is offline
Boat: Prostar 197
How do you determine if it is the cutlass bearing or the prop? I have the same vibrations out of the hole.
Old 05-31-2017, 11:41 PM
Boat: Prostar 197
Or do you just replace both?
