Old 07-24-2014, 05:11 PM
masterx10 masterx10 is offline
Boat: 2014 Mastercraft X10
PDS Diagnostic Screen
Does anyone know anything about the PDS Diagnostic screen on the 7 inch display on a 2014? Under the Analog Inputs I have a red dot indicated for the Starboard ballast sender saying that it has a "short circuit / Analog out of range". The forward and port ballast sender have green dots indicating no fault. It was my understanding that the ballast do not have senders and the levels were determined by timers. Is this correct? Should I be concerned by the red dot?
Old 07-24-2014, 05:42 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
I would think there is a fault somewhere, otherwise you wouldn't get a fault message, either something wrong with the ballast or maybe software issues, time for a visit to the dealer imo.
/spôrk/
Old 07-24-2014, 08:45 PM
FourFourty's Avatar
No senders on the 2014, and my x30 shows the same thing. Never had any problems with anything on the boat after 75hours of use so far.
Old 07-25-2014, 02:20 AM
Stefan's Avatar
Stefan Stefan is offline
I'm pretty sure there are ballast tank senders in the 2014's, at least my X46 has them. But I've seen faults like that from time to time and never had troubles...
Old 07-25-2014, 06:02 AM
FourFourty's Avatar
My x30 doesn't have them, I wanted to know if it did, so I removed the little covers where they go. No sender, just a blank cover plate.
Old 07-25-2014, 08:02 AM
Thanks for the replies. My dealer is about a 3 hour round trip and I took the boat twice in June for warranty work so was hoping to not have to return to them anytime soon. We are in the middle of winter down here so I will not be able to use the boat for a couple of months to test the ballast pump.
FourForty, are the little covers you are talking about about half way along the top of the ballast tank on the engine side?
Old 07-25-2014, 08:35 AM
DHPRO's Avatar
DHPRO DHPRO is offline
Boat: 2014 Gen II X30 SS
ditto...55hrs so far and I treat it like a warning system. It tells us nothing that we can use to remedy any situations without taking it to the dealer has been my experience so far. Once I get enuf faults I take it in for service assuming nothing catastrophic has happened.
Old 07-25-2014, 09:39 AM
FourFourty's Avatar
Yes, if you remove that cover, you will see the spot on the ballast tank where a sender would go. Mine just has blank metal covers, that seal off the sender hole.
