Old 07-11-2014, 06:40 PM
TallSkinnyGuy TallSkinnyGuy is offline
Boat: 1997 Prostar 190
Corrosion -- something to replace? '97 PS190 350 tbi
While looking around at the back of the engine due to an unrelated issue I shined my light down in the area on the starboard half of the back of the engine and noticed that the terminals for the black wires with the yellow stripe in the middle of the picture below are very corroded and there is a defined "pool" of rust-colored bumpiness on the wall where the wires are connected.
There are a ton of electrical connections back there and I didn't want to start messing with stuff until having a better understanding of what this is. I'm guessing corrosion is bad and I should replace these wires and clean up the area, but is there anything I need to be careful of when doing this? Any particular process that must be followed?
Old 07-11-2014, 07:16 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
To be on the safe side,disconnect battery then remove, clean and thighten.
Not seing the corrosion very well...
Keep skiing!!!
Old 07-11-2014, 07:17 PM
Disconnect battery take apart clean... Reassemble attach battery ... I did this on mine
Old 07-11-2014, 07:29 PM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 2008 22' Progression
When you back out those cad plated bolts You will find all the engine harness grounds. There should be at least three or four make sure they are clean.
