Old 07-04-2014, 05:42 PM
Bethelbumblebee Bethelbumblebee is offline
Boat: Mastercraft X30 2006
Taking on water
We took our '06 X30 out today for the first time this season, and the bilge pumps were constantly pumping out water from the minute we got into the water until 5 min. after we got out. We ran for about 20 minutes and came back. The plug was in. Where is the water coming from?
Old 07-04-2014, 05:46 PM
Table Rocker's Avatar
Ballast hoses might be loose or off from winterization. You can't see or hear where it is coming from?
'96 ProStar 205 SD LT-1
are all hose connected tight? port block plug installed? knock sensor installed? was boat properly winterized? possible freeze plug pop? broken hose?
Check your rudder box and your shaft seal...
Ballast hose leaking? if plumbed ballast?
Old 07-06-2014, 12:11 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Shower left on? Even wo pump it made my bildge run like that.
Bad heater core?
Table Rocker gave some good suggestions too
Sent from my SCH-I435L using Tapatalk
2004 Prostar 197, ACME 843
Old 07-06-2014, 02:00 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Only while engine was running?
There are many places for it to leak. Run it out of the water on a hose. If it doesn't leak then you've eliminated the cooling system and shower.
My X2 had a severely dry rotted and cracked main ballast intake line. I found it winterizing when I disconnected it. Would have been a big leak.
'06 X2 MCX
Old 07-06-2014, 03:08 PM
bturner2's Avatar
bturner2 bturner2 is offline
Yeah with the first time out after being winterized I'd be looking for loose hoses, block drains and the hose that drains the two exhaust manifolds. Did you take a look while you were out? A leak that big should have been very noticeable.
